JDM H22 Wiring Schematic Needed
Old Mar 15, 2005 | 04:18 PM
BillClinton's Avatar
Default JDM H22 Wiring Schematic Needed
I need h22 wiring schematic for a 93 H22 with internal coil.
Old Mar 17, 2005 | 02:54 PM
ANDREW D's Avatar
Default Re: JDM H22 Wiring Schematic Needed (BillClinton)
Bill Clinton
Old Mar 18, 2005 | 09:05 AM
SiR EJ8's Avatar
bump i need this too
Old Mar 18, 2005 | 12:51 PM
SiR EJ8's Avatar
bump again. mainly the ecu wiring schematic. sort of the ecu pinout but with a detailed description of what the pins do. not some barely readable abbreviations.
Old Mar 18, 2005 | 01:10 PM
IHateJDM's Avatar
Default Re: (SoLo Accord)
I have one saved on my computer I can post in a couple hours when I'm home, but it's info I got from searching this site.
Old Mar 20, 2005 | 07:12 AM
ANDREW D's Avatar
Old Mar 20, 2005 | 11:06 AM
2point2's Avatar
http://tech2.hybridgarage.com/..._obd1
same pins as a GSR (p72) ecu..
^^ this is how you count pins.
Old Mar 20, 2005 | 12:02 PM
IHateJDM's Avatar
Default Re: (2point2)
OBD1 P13 Pinout Guide
Contact Color Description
A1 brn Injector #1
A2 yel Injector #4
A3 red1 Injector #2
A4 grn/yel VTEC Solenoid Valve
A5 blu Injector #3
A6 or/wht HO2S heater coil
A7 grn/blk1 PGM-FI Main Relay coil
A8 grn/blk2 Shorted to A7
A9 blk/blu IAC Valve
A10 - -
A11 red2 EGR Control Solenoid
A12 blu/red Condenser Fan Relay
A13 blu/wht MIL
A14 - -
A15 red/blu A/C Clutch Relay
A16 wht/grn Alternator
A17 pink IAB Solenoid Valve
A18 - -
A19 wht Intake Control Solenoid Valve
A20 red/grn EVAP Purge Control Solenoid
A21 yel/grn1 ICM
A22 yel/grn2 Shorted to A21
A23 blk1 GND
A24 blk2 GND
A25 yel/blk PGM-FI Main Relay (power)
A26 blk/red VTEC Pressure Switch (GND)
B1 yel/blk PGM-FI Main Relay (power)
B2 brn/blk GND
B3 - -
B4 - -
B5 blu/blk To A/C Switch
B6 - -
B7 - -
B8 red/grn PSP Switch
B9 blu/red Starter Cut Relay
B10 orn2 VSS
B11 orn3 CYP
B12 wht CYP
B13 orn/blu TDC
B14 wht/blu TDC
B15 blu/grn CKP
B16 blu/yel CKP
D1 wht/yel Battery
D2 grn/wht1 Brake Switch
D3 red/blu KS
D4 brn/wht SCS
D5 - -
D6 lt blu or lt grn VTEC Pressure Switch
D7 lt grn/red Data Link Connector
D8 - -
D9 wht/red ALT
D10 grn/blk ELD
D11 red/blk TP Sensor
D12 wht/blk EGR Valve Lift Sensor
D13 yel/blu ECT Sensor
D14 wht HO2S Sense
D15 red/yel IAT Sensor
D16 - -
D17 wht/blu MAP Sensor
D18 - -
D19 red/wht EGR Valve Lift Sensor
D20 yel/wht TP Sensor
D21 blu/wht MAP Sensor
D22 grn/wht2 TP Sensor
Old Mar 21, 2005 | 06:19 PM
BBBump
Old Mar 21, 2005 | 07:45 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BillClinton &raquo;</TD></TR><TR><TD CLASS="quote">BBBump</TD></TR></TABLE>
more like lock.
what the heck else do you need? if you need more detailed wiring schematics buy a manual.
Old Mar 22, 2005 | 07:01 PM
ANDREW D's Avatar
Default Re: JDM H22 Wiring Schematic Needed (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
more like lock.
what the heck else do you need? if you need more detailed wiring schematics buy a manual. </TD></TR></TABLE>
Your help is appreciated I'm sure, but that is a chart, not a schematic. A schematic is a diagram, not a chart. Anyway, where could you even find a manual with the info he is looking for?
allhonda
Oct 4, 2006 06:20 AM
force-fed
Oct 5, 2005 05:00 AM
OutlawCL
Mar 14, 2005 03:37 AM
B18A1-ED6
Oct 25, 2004 03:24 PM
RaceTUNE
May 20, 2003 08:39 AM
