did compression test, healthy?
Old Mar 15, 2005 | 04:09 PM
luckypon7's Avatar
Default did compression test, healthy?
what do you think guys, just did my compression test. piston suppost to be 11:5:1 compression. here are the numbers. is the motor in good shape? thanx 98 gsr motor head and block
test 1 test 2
cyl 1- 239 psi 240 psi
cyl 2- 231 psi 231 psi
cyl 3- 240 psi 240 psi
cyl 4- 240 psi 240 psi
Modified by luckypon7 at 8:34 PM 3/15/2005
Old Mar 15, 2005 | 04:23 PM
JDM JEFFREY's Avatar
Default Re: did compression test, healthy? (luckypon7)
you should have more compression
I have a 1.8L ls/vtec with JE 11:5:1 compression pistons and I had 275 on all 4
Old Mar 15, 2005 | 06:26 PM
drdisco69's Avatar
Default Re: did compression test, healthy? (JDM JEFFREY)
Different gauges read differently, just like dynos. As long as the readings are consitant between cylinders, it's okay.
You're a little low on cylinder 2, but thats the hot one, and probably to be expected. Over all it looks very good, I would be happy.
Old Mar 15, 2005 | 07:43 PM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckypon7 &raquo;</TD></TR><TR><TD CLASS="quote">what do you think guys, just did my compression test. piston suppost to be 11:5:1 compression. here are the numbers. is the motor in good shape? thanx 98 gsr motor head and block
test 1 test 2
Modified by luckypon7 at 8:34 PM 3/15/2005</TD></TR></TABLE>
which camshafts are you using and how are they currently adjusted on the cam gears ? that will make a big difference in compression test pressure. Given that 3 cyl are similar and one slightly less I'd say you're fine.
Greg
Old Mar 15, 2005 | 07:51 PM
onepoint6i's Avatar
Default Re: did compression test, healthy? (CHEETAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">
Greg</TD></TR></TABLE>
thats what i was thinking..also valve lash makes difference in numbers i've heard
Old Mar 16, 2005 | 06:04 AM
luckypon7's Avatar
which camshafts are you using and how are they currently adjusted?
i'm using the stock gsr cams and gears.
thanks for the comments guys
Old Mar 16, 2005 | 08:46 AM
scUba-stEve's Avatar
not trying to thread jack but j/w if my compression test was okay too...i dont know what compression exactly but i have wiseco 11.8:1 with a milled head...about .020 milled...so looking to be around 12:1+/-...anyways i'm using crower stage 2 cams, VL .007/.008.
cyl. 1...250
cyl. 2...250
cyl. 3...255
cyl. 4...245
the motor only had about 300-400 miles on it at the time...hoping that the rings will seal up a little bit more as i put more miles on it...what do you think?
Old Mar 16, 2005 | 08:52 AM
drdisco69's Avatar
Default Re: did compression test, healthy? (zer0-psi)
Those numbers are fine. Consistant across the cylinders is what is important.
boosted k20
Apr 21, 2005 04:55 PM
SPOON_FED_DC_2
Apr 6, 2005 09:19 PM
projektCRX
Apr 22, 2004 12:18 PM
Team 4
Dec 5, 2003 03:38 PM
HatchBox
Aug 4, 2003 03:41 PM
