After wreck hood bulge...?
Old Mar 15, 2005 | 04:09 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default After wreck hood bulge...?
I wrecked my CRX months ago, and hundreds of dollars later I'm about ready to start driving her again... I'm having trouble with my hood though. All the body lines on the car are fine, but when I try to latch my hood now, the rear of it bulges a lot and it won't shut right. I'm not sure why this is happening. Any ideas? Should I just use washers to get it lined up again? Thanks for any input.
Old Mar 15, 2005 | 08:35 PM
99sonicbluegsr's Avatar
Default Re: After wreck hood bulge...? (crxzcracer)
boy i think you need to get your (10) out and just play with it. bulging sounds like a personal problem to me. just messin with you chris. bump for MIDDLE TENNESSEE TURBO
Old Mar 15, 2005 | 08:48 PM
CRX_1.8T's Avatar
Maybe try to remove the hood and check out all of the places where it connects to your CRX; like the 2 hinges, and the latch piece between your headlights.
Old Mar 16, 2005 | 01:26 PM
crxzcracer's Avatar
Default Re: After wreck hood bulge...? (CRX_1.8T)
Well it all looks good and lines up it just when i go to shut it i have to slam it hard and you can see where it rises in the center and just so you know it no the hood i got in the wreak with it my stock hood my cf got owned
Old Mar 16, 2005 | 01:53 PM
manson's Avatar
do you have a swap?
could it be hitting your motor?
any rub marks on the hood or valve cover?
Old Mar 16, 2005 | 03:52 PM
crxzcracer's Avatar
Default Re: After wreck hood bulge...? (manson)
i do have a swap but i lowered the eng. on that side so it not hitting
Old Mar 17, 2005 | 05:00 AM
manson's Avatar
the OEM hood has alot more material under the hood. i would really take a good close look to see if its infact making contact. if the hood is buldging in the center.... what else could it be?
Old Mar 17, 2005 | 06:31 AM
crxzcracer's Avatar
yeah i know it would seem to be the eng. but i had this hood on befor with the swap and it worked i have also placed tape upside down on the eng shut the hood so if the hood was hit any the tape would stick and i would know thats the spot that hit but it didnt.
i think it has something to do with the little clip on the front of the hood that locks in i think it needs top be down farther than it is but i cant get it to unscrew to make it longer i go crazy on it today and see what i can do.
///Nick
Jan 12, 2011 01:21 PM
Mr.Touchdown
Oct 5, 2006 04:48 PM
Black Maverick
Jun 23, 2006 08:37 AM
HaRd KoRe CRXtasy
Sep 5, 2004 10:48 AM
t0ekn3e
Jul 9, 2004 11:27 PM
