H23 wire harness on H22
Old Mar 15, 2005 | 03:54 PM
BillClinton's Avatar
Default H23 wire harness on H22
I tried to install a H22a from Japan into my 93 USDM H23 Prelude. I started it and it runs but it has no power and the tach only worked once intermittently. I got a code 15 which is engine output signal. I think that my problem is with the wiring between the tach and where the coil was from the H23, however the H22 has an internal coil. Can anyone please help this child? Does anyone have a schematic for the Japanese H22A w/internal coil?
Old Mar 15, 2005 | 03:56 PM
Default Re: H23 wire harness on H22 (BillClinton)
Im sorry:
The problem might be the wiring between the distributor and coil.
Old Mar 15, 2005 | 04:02 PM
Greyout's Avatar
Use your H23 distrbutor & Coil
edit: oops, saw that you did that - it should be a plug & play switch....
Old Mar 15, 2005 | 04:14 PM
Default Re: H23 wire harness on H22 (Greyout)
I did that too and still the same.
sscivicsi
Jun 15, 2008 10:05 AM
ASUJA
Jun 4, 2008 07:12 PM
logicdc
Oct 22, 2007 06:12 PM
civic919900
Jul 31, 2007 10:25 AM
maxxedsx
Feb 19, 2006 12:59 PM
