Key stuck in ignition HELP!
I have a 91 civic, i just converted it to a manual. the key wont come out of the ignition because the car is not in park
(dosnt exist anymore). How do I fix this? Help!
I remember having seen people bypass it. Its a sensor or something like that. Search around, it wasn't long ago. Or you could try to look at a wiring diagram for the automatic version of the car and bypass the sensor/switch that locks it.
From: I told you to wait in the truck in Texas, United States
"This one is easy to spot because it has two heavy black wires instead of the other with two yellow wires. Just connect them in a simple loop." Believe it or not i used yur advice to do the whole conversion. I took the harness with the two black wires and made a loop that attached them both together but it dosnt work. Did I connect it right?
thanks alot
thanks alot
i'm sorry guys but i was laughing so freakin hard as i read this.
it kinda reminded me of the first time i drove my mustang. Story goes somthing like...driving off from the lot, getting to best friends house and key won't come out. But on fords there is a littl ebutton under the steering wheel i didn't know about.
Anyways that site says exactly how to so good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_valentino20032000 »</TD></TR><TR><TD CLASS="quote">i'm sorry guys but i was laughing so freakin hard as i read this.
Sorry you had to drive that thing
</TD></TR></TABLE>Sorry you had to drive that thing
heh my old silverado had one of those too...only exception: i could take out the key when it was running
</TD></TR></TABLE>heh my old silverado had one of those too...only exception: i could take out the key when it was running
Well the problem to me sounds like you need to get a new computer that is set up for a manual transmissin because it is still sending the signal for the automatic gearing. Or you might need to get a new ignition if that dont work
