obd2 > obd1 help starting
just swapped a 95ls into my 99ls(<hydrolocked) i am using everything from my old motor (manifolds,tranny,dist.etc.) onto the 94b18b
timing is set to 0, hoses and sensors are intact. when i go to start the engine all it does is crank. am i missing anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost Lee »</TD></TR><TR><TD CLASS="quote">just swapped a 95ls into my 99ls(<hydrolocked) i am using everything from my old motor (manifolds,tranny,dist.etc.) onto the 94b18b
timing is set to 0, hoses and sensors are intact. when i go to start the engine all it does is crank. am i missing anything?</TD></TR></TABLE>
ignition timing is set to 0? it should fire 16 degrees btd at idle
check for spark and check for fuel
If they smell w/ gas, then that means the injectors are spraying them when they aren't firing? Bear with me here, I'm not a mechanic, and I've only fixed my own little problems, but that seems logical. Maybe the timing is off like TurboSmart suggested?
00WhiteEKy
Oct 21, 2004 11:11 AM
