Crank, but no start.
I know it's not a ITR, but I trust you guys a lot more, so here is my post copied from the Integra forum.
I drove home Sunday night 50 miles with no problems. Turned the car off, went out to start it a couple hours later and it just cranked. I installed a stereo on Saturday, but I don't see how it could be a factor.
Things I've done so far:
Changed the battery.
Checked spark, had spark on all 4 cylinders.
I can hear the fuel pump and rail.
I pulled the distributor cap and the rotor looks a bit scorched and the nodes on the cap look corroded a bit. I'm about to crank it and pull a plug to make sure I'm getting fuel.
Any suggestions?
TIA
Update, just cranked and pulled a plug. It was wet with gas so that ruled that out.
Checked spark again and it was definantely blue, which from what I understand means a weak spark. Not enough to ignite the fuel?
I'm going to track down a cap and rotor and see what that does.
99 GSR with 59k btw.
Any suggestions?
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">fuel issue, maybe ignitor</TD></TR></TABLE>
The plugs were wet with fuel, it's a weak spark of some sort I would think. After looking at the condition of the rotor I would suspect that it was that. So I'm going to change that out in the morning then go from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">could be the coil or ignitor...j00 check if j00 have spark at all?</TD></TR></TABLE>
Yea, re-read the post. I'm going to replace the cap & rotor tomorrow morning cause no one had one today and see what that does. The rotor looks like poo. If that doesn't work then I'm going to check the coil & ignitor. If it's not that then I'm going to have to check if I jumped teeth
DRxCIVIC
12
Apr 20, 2003 04:01 PM
Jason kiDD
Mar 19, 2003 07:54 AM
