Having trouble w/ lowering my teg (TOKICO)!!!
Old Mar 15, 2005 | 02:38 PM
jdmjeff's Avatar
Default Having trouble w/ lowering my teg (TOKICO)!!!
i hava tokico coilovers and tokico shocks. I tried to lower my car like 3 times but i cant get the damn thing to lower. i have the keys to lower it, i even tried some bolt loosener (sp?) and i also tried to clamp them together but nothing worked!!! i need some help... also the springs are compressed but i dont think this should matter! HELP! THANKS
Old Mar 15, 2005 | 03:01 PM
AlphaQup's Avatar
Default Re: Having trouble w/ lowering my teg (TOKICO)!!! (jdmjeff)
I'm guessing they are coilovers, and not regular springs?
Old Mar 15, 2005 | 03:46 PM
Finger Lickin' good's Avatar
Default Re: Having trouble w/ lowering my teg (AlphaQup)
reverse threads. i got the illumniaR's. Top one turn clockwise, bottom Counter clockwise. I think.
Old Mar 15, 2005 | 07:59 PM
jdmjeff's Avatar
Default Re: Having trouble w/ lowering my teg (D-CeReaL#4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 &raquo;</TD></TR><TR><TD CLASS="quote">reverse threads. i got the illumniaR's. Top one turn clockwise, bottom Counter clockwise. I think. </TD></TR></TABLE>
yeah they are coilovers and i know how they turn... but they WONT MOVE! has anyone else had this problem!!!!
Old Mar 15, 2005 | 08:13 PM
Red96Integra805's Avatar
Default Re: Having trouble w/ lowering my teg (jdmjeff)
thats why i took my coils off..they got stuck where i couldnt move em up or down.
Old Mar 16, 2005 | 10:50 AM
jdmjeff's Avatar
bump
Old Mar 16, 2005 | 10:56 AM
purplegsr's Avatar
Does it have 2 perches (a locking one and the top one)? If so, hit the bottom one in the teeth with a flathead/hammer combo until it turns enough in one direction to separate from the top one. Whenever mine are stuck, they tend to turn together. Then you should be able to do the same thing to either loosen or raise the regular perch. I have had to do this whenever my old koni coilovers have a tough time moving.
Old Mar 16, 2005 | 12:02 PM
jizno's Avatar
throw em in the garbage and buy some teins, worthless tokico coilovers
Old Mar 16, 2005 | 05:45 PM
DynastyRacer22's Avatar
Default Re: Having trouble w/ lowering my teg (jizno)
can i have it wen u throw it away? lol
Old Mar 16, 2005 | 05:52 PM
bo2o's Avatar
Default Re: Having trouble w/ lowering my teg (DynastyRacer22)
check if theres a hex key on it, you might have to loosen it... haha
if thats broken and round it drip thru it and then lower it to wher you want it then use one ob those screw on clamp things that u you put on your intake or radiator hose
Old Mar 16, 2005 | 07:46 PM
RidinStock's Avatar
Default Re: Having trouble w/ lowering my teg (bo2o)
I had some cheap $150 dollar coilovers back on my old DA, and when I tried to change the height, they were stuck together so bad that I used the hammer technique. Worked for me. I'm not sure what you mean by "key" but does it have about 6 teeth around each top and bottom perch where you put one "key" on one way and the other the opposite to turn them separate? If this is the case, attach one to the bottom and hammer in the correct direction. It should work, they can get really stuck together.
Old Mar 18, 2005 | 08:16 PM
jdmjeff's Avatar
bump!
Old Mar 18, 2005 | 09:06 PM
RidinStock's Avatar
Did I have the right idea? You never answered my ?'s to help narrow down your problem.
Old Mar 22, 2005 | 09:44 AM
jdmjeff's Avatar
Default Re: Having trouble w/ lowering my teg (RidinStock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">Did I have the right idea? You never answered my ?'s to help narrow down your problem.</TD></TR></TABLE>
I know how to get them off but they are "stuck on" they will not move even with the keys and bolt loosener and a clamp...
Old Mar 22, 2005 | 03:37 PM
Irish Integra's Avatar
Good old cheap coilovers! Mine are the same, was going to lift her a bit, but just can't be bothered now!
If they won't turn with a hammer and screwdriver, the threads are probably damaged from having the weight of the car sitting and bouncing on them, you might have to take out the springs and try to loosen the adjuters on a bench...what a bitch!
Old Mar 22, 2005 | 07:25 PM
jdmjeff's Avatar
Default Re: Having trouble w/ lowering my teg (Irish Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irish Integra &raquo;</TD></TR><TR><TD CLASS="quote">Good old cheap coilovers! Mine are the same, was going to lift her a bit, but just can't be bothered now!
If they won't turn with a hammer and screwdriver, the threads are probably damaged from having the weight of the car sitting and bouncing on them, you might have to take out the springs and try to loosen the adjuters on a bench...what a bitch!</TD></TR></TABLE>
yeah sounds good that probably what ill have to do but i might just buy 2 off of H-T cheap
Chillmatic
44
Apr 6, 2008 07:30 PM
walsh22
28
Dec 13, 2006 01:00 AM
hybrid_vtec
May 30, 2005 06:53 PM
Nader_D
Apr 17, 2003 06:47 AM
mattmw88
Jan 29, 2002 08:14 PM
