HELP
Old Mar 15, 2005 | 02:01 PM
NinjaTech's Avatar
Default HELP
What happens if i accidently put in to much oil into my engine after changing it? can it damage it?
Old Mar 15, 2005 | 02:04 PM
HATCHingMN's Avatar
Default Re: HELP (Chandelt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chandelt &raquo;</TD></TR><TR><TD CLASS="quote">What happens if i accidently put in to much oil into my engine after changing it? can it damage it? </TD></TR></TABLE>
what do you mean too much??
how many quarts do you use? and what motor?
Old Mar 15, 2005 | 02:05 PM
NinjaTech's Avatar
3.7 quarts it said and i have a d17a stock
when i refilled my engine oil i think i put in to much. Can it damage the engine if it has to much? what will happen
Old Mar 15, 2005 | 02:12 PM
prettyQuik's Avatar
i did that once when i thought i was leaking oil, but really wasnt. you will get to much oil in your head and smoke like crazy. if that doesnt happen, i wouldnt be worried, it will eventually burn off
Old Mar 15, 2005 | 02:13 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chandelt &raquo;</TD></TR><TR><TD CLASS="quote">3.7 quarts it said and i have a d17a stock
when i refilled my engine oil i think i put in to much. Can it damage the engine if it has to much? what will happen</TD></TR></TABLE>
3.7 is just right.
Old Mar 15, 2005 | 02:47 PM
hatch34's Avatar
Default Re: HELP (HATCHingMN)
if you have way to much oil you can blow out your seals becasue of the added pressure from all the oil. if its to much just let a little out as if you were changin the oil just let some out and check it and if you took to much out then just add a little .
turboteg90
Feb 11, 2008 08:07 PM
qwk db8
Dec 31, 2007 03:56 AM
97dc2
Aug 3, 2005 09:39 PM
2k1 itr
Jan 19, 2004 03:56 AM
