Hard clicking noise when turning left!
Old Mar 15, 2005 | 12:56 PM
D16Z6_turbo's Avatar
Default Hard clicking noise when turning left!
I'm hearing some hard clicking noises when i take a left turn in my EG. Also it has a faint whining sound when i'm cruising the highway at 70MPH and the car pulls really hard to the right on some occasions. Anyone have this problem before. Oh by the way, the axles are brand new. Any help would be appreciated!
Old Mar 15, 2005 | 12:59 PM
Junk Ex's Avatar
Default Re: Hard clicking noise when turning left! (D16Z6_turbo)
Could be a shot axle or wheel bearing, I would check both out. The only way you can tell if a axle is bad is by hearing it so that would be my guess and the noise at highspeeds is prolly the wheel bearing.
Old Mar 15, 2005 | 01:28 PM
HitEm'Up's Avatar
Wheel bearing on the whining noise The clickin usually is a axle but..if theyre new, i would say take a look at the suspension make sure everything is tight
Old Mar 15, 2005 | 03:13 PM
del_orson's Avatar
Default Re: Hard clicking noise when turning left! (98JRSChatch)
100% its the axle
Old Mar 15, 2005 | 03:26 PM
All Motor EH2's Avatar
Default Re: Hard clicking noise when turning left! (del_orson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote">100% its the axle</TD></TR></TABLE>
Old Mar 15, 2005 | 03:35 PM
Not_So_Average's Avatar
There is such a thing as getting defective axles, especially when they are remanufactured axles.
The whine is 100% a wheel bearing, but to make sure, when it is whining, cut the wheel back and forth slightly and see if the noise disappears, if so, then that is your guarantee on the wheel bearing.
Old Mar 15, 2005 | 04:35 PM
94CoupeEJ1's Avatar
Default Re: Hard clicking noise when turning left! (Not_So_Average)
Yes remanufactured half shafts can be defective. I found this out the hard way not long after the warantee ran out. They are still a good deal because compared to new ones they are cheap.
Old Mar 15, 2005 | 05:01 PM
matthevelli's Avatar
pretty sure there the axles..give them a look over along with your wheel bearings!!
Old Mar 15, 2005 | 07:54 PM
Default Re: Hard clicking noise when turning left! (matthevelli)
Would i need a press to take out the bearing?
Old Mar 16, 2005 | 12:13 PM
JarvisW's Avatar
Sol to Sol
I'd like to know too.
Old Mar 16, 2005 | 12:17 PM
IHateJDM's Avatar
Yep, wheel bearings have to be pressed in.
Old Mar 16, 2005 | 12:18 PM
9 9 c i v i c's Avatar
Default Re: Hard clicking noise when turning left! (93delslo)
axle
Old Mar 16, 2005 | 06:18 PM
HBADGE's Avatar
Make sure everythings tightened good! The idiots who did my alignment "forgot" to tighten a bolt. Also check your axles.
Old Mar 16, 2005 | 06:33 PM
ramrod's Avatar
Default Re: Hard clicking noise when turning left! (EG-4D)
definately check axles. check for axle grease on tranny and sub-frame by the boots. clicking + splattered axle grease = bad axle/boot. not sure about whining. best of luck
Old Mar 16, 2005 | 06:40 PM
Default Re: Hard clicking noise when turning left! (skunked_EK)
Axles are new and the boots are still good. This is getting weird, it only happens once in a blue moon...
Old Mar 16, 2005 | 07:02 PM
92lsvteceg6's Avatar
Default Re: Hard clicking noise when turning left! ("95civic")
def. an axle and possible bearing
Old Mar 17, 2005 | 09:43 AM
jharper's Avatar
Most likely the axals. Are they stock rims. my 95 civic was making a lot of clunking noise and it turned out that one of the rims wasn't sitting right on the hub.
Old Mar 17, 2005 | 11:01 AM
b204dr's Avatar
the clicking and whinning is the axel - spend the money replace it - if its still there its the bearing ! but its already been asnwered
Old Mar 17, 2005 | 11:23 AM
Econo'Box's Avatar
Default Re: (b204dr)
It's deffinately the axle. Don't let it run like that for very long or will will break the hub bearing and steering knuckle.
Old Mar 17, 2005 | 11:37 AM
robbieshonda's Avatar
Default Re: (tabrisakakaoru)
If you want a write up on how to replace your bearings lemm eknow Ill whip one up.
dc2doi
Oct 15, 2007 11:23 AM
GSR_hatch936
Sep 7, 2007 01:19 PM
TylerW
Sep 5, 2005 09:39 PM
KMk51188
14
Sep 2, 2005 06:31 AM
REDBARON
14
May 24, 2001 07:25 PM
