b16 dohc 1st gen head on a b18a1 ls block code 23 knock sensor?
hi,
i bought a 90 civic hatch si with a b16 dohc v tec head and b18a1 block (i believe its from an integra ls) i get code 23 ..i have searched and i keep getting the same response that the ls block doesnt have a knock sensor
i also get backfire occasionally
the computer # is 37820-pw0-000
250-317818MA
im not sure if its a p28 or a po6 the computer also has writing with permanent marker "SIR V TEC"
i didnt do the swap so i dont know what to do..ive searched but i cant get a concrete answer ....please help
250-317818MA
Correct the LS block does not have a knock sensor but the ecu you have is looking for one. You probably have a OBD0 PR3 of PW0 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">Correct the LS block does not have a knock sensor but the ecu you have is looking for one. You probably have a OBD0 PR3 of PW0 ecu</TD></TR></TABLE>
how do you fix this
how do you fix this
Either have the ecu chipped so it doesn't look for the knock sensor or install a knock sensor in the LS block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t »</TD></TR><TR><TD CLASS="quote">what is the correct procedure for doing this</TD></TR></TABLE>
bump
bump
Hers'a link to the complete swap info. it's explains where to drill/tap the knock sensor in place.
http://www.sportcompactcarweb....ybrid/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t »</TD></TR><TR><TD CLASS="quote">the computer # is 37820-pw0-000
i *think* he's running a pw0, guys.
type-t
Mar 26, 2005 01:11 PM
