ignition timing on my 91 crx with sohc jspec zc d16a6 replacment
Old Mar 15, 2005 | 09:11 AM
dscrxsi20's Avatar
Default ignition timing on my 91 crx with sohc jspec zc d16a6 replacment
I just swapped out my d16a6 for a j-spec replacment. and i dont know if the ignition timing is the same. and if it is the same which mark on the crank am i supposed to allign it with. my hays manual says to look under the hood. but i have an aftermarket hood. so i have no idea what im doing. please help.
Old Mar 15, 2005 | 09:13 AM
Exempt's Avatar
There should be a mark above the crank pulley....
Old Mar 15, 2005 | 09:21 AM
dscrxsi20's Avatar
Default Re: (Exempt)
which of the 4 marks on the crank
this is what the crank mark looks like, but i dont know which one to allign the timing mark to.
| | | | thats what the marks look like on the crank pulley.
#1 #2 #3 #4
which number to i allign my mark to?
Old Mar 15, 2005 | 09:36 AM
EP3_05's Avatar
Default Re: ignition timing on my 91 crx with sohc jspec zc d16a6 replacment (dscrxsi20)
There should be four marks. Three in a group and one all by itself. The one by itself is used to set tdc when installing the timing belt. The other three are the timing marks. You should set the timing to the middle mark which is stock timing.
Old Mar 15, 2005 | 08:23 PM
dscrxsi20's Avatar
Default Re: ignition timing on my 91 crx with sohc jspec zc d16a6 replacment (91civic)
im supposed to set my timing to 10 degrees which mark is that? do you know? thanks for the help to.
Old Mar 16, 2005 | 09:04 PM
Exempt's Avatar
10 degrees retard, or 10 degrees advanced?
Heres a how-to on adjusting timing... Should help u out some...
http://www.sohchonda.com/artic...=0005
jimmak85
Aug 2, 2011 06:03 PM
SloCivicHMM
Nov 8, 2004 02:30 PM
civbeater90
Nov 16, 2002 12:46 PM
echo999
Jun 9, 2002 07:39 PM
