G2 teg owners i need help with 1 piecers with hids
Old Mar 15, 2005 | 09:00 AM
markwitdada9
Guest
Posts: n/a
Default G2 teg owners i need help with 1 piecers with hids
i dont kno how to fit my hids into my 1 piecers. im not goin to put the projector in the 1 piece headlights i just wanna see some pics of how you have the bulb in the headlights...i have been using tape to hold my bulbs in but it suxz tho cuz almost after every rain i gotta go and re do them.. so help me out n give me some ideas.. iite thanxz
-mark
Old Mar 15, 2005 | 11:33 AM
markwitdada9
Guest
Posts: n/a
Default Re: G2 teg owners i need help with 1 piecers with hids (markwitdada9)
anyone ?
Old Mar 15, 2005 | 11:58 AM
VDo's Avatar
VDo
What kit are you using? I've been running retrofitted kit from a CL for more than 2 years without a problem.
Heres how I secured the bulb:
H4H vs D2R. Notice the similar mounting depth and diameter.
Notched the bulb at the base and the back:
Secured with coathanger wire to stock mounts:
Replace boot:
Done:
Old Mar 15, 2005 | 12:04 PM
Slain's Avatar
you have to dremel the base of the hid bulbs. to make it fit. you will need to make a glare sheild as well. the glare will be off the hook if you just place the hid bulbs in there as is.
http://www.g2ic.com/forums/sho...t=hid
make sure you make a glare sheild that covers the bottom of the bulb. http://www.hidplanet.com for more on hid applications
Old Mar 15, 2005 | 12:06 PM
Slain's Avatar
oh nevermind lol vdo beat me to it with his write up lol
Old Mar 15, 2005 | 10:54 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (Slain)
I was trying to retofit some HId's to my projectors, what do u think ill need?
Old Mar 18, 2005 | 01:19 PM
1SiKDA8's Avatar
Default Re: G2 teg owners i need help with 1 piecers with hids (VDo)
u have such a sweet teggy!!! i have a 92gs, nutin 2 b 2 proud of rite now, (only a few mods dun so far) but I'm workin on her. i was just askin around today bout this light stuff, glad i found u guys. i wanna go w 1piece w HID what do i need to do and buy. I'm kinda new to this imports stuff, and need advice, i'd been drivin american 4 to long, and finally made the switch. what u got in ur car??
Old Mar 18, 2005 | 01:52 PM
platinumg2's Avatar
Default Re: G2 teg owners i need help with 1 piecers with hids (1SiKDA8)
please dont just plug in on onepieces, overall output might be bright but garantee youll be blinding on coming traffic. how do i know, cause i first did it that way. ive then decided to install projectors to limit the glare. the fluted lens pretty much distorted my cutoff but overall its 100X better than h4h or when simply just plugging it in....
Old Mar 19, 2005 | 08:53 PM
Slain's Avatar
i have e46 bixenons in my one pieces i did it about a year ago.
Old Mar 19, 2005 | 09:02 PM
PatrickGSR94's Avatar
Community Builder
Active Streak: 60 Days
Default Re: G2 teg owners i need help with 1 piecers with hids (platinumg2)
If you really want the best output, you need to not only put OEM HID projectors into the 1-piece housings, but also sand and polish the flutes off of the lens in front of the projector. Then you will have a nice sharp cutoff and wide beam output that won't be dangerous to oncoming drivers. Yes on backroads the glare can be quite dangerous if uncontrolled, it could cause an oncoming driver to run off the road.
naz0o
Honda Civic (2006 - 2015)
Jan 1, 2009 06:59 PM
NINE9DC4
Jan 2, 2006 07:01 PM
CrazyModGSR
May 3, 2004 09:32 PM
LuckyNuts
Nov 12, 2003 04:13 AM
ic108
Apr 12, 2002 08:50 PM
