urgent: atts question
Old Mar 15, 2005 | 03:07 AM
The Wizard of Lude's Avatar
Default urgent: atts question
a friend is selling is type s prelude (and i'm thinking of buying it) but atts on that is goosed. is the atts transmission swapable with a non-atts stock vti prelude trans, same gen or 4th gen ? or can it be turned off altogether since it is goosed and driven normally ? any ecu modifications required on swap ?
thanks a bunch
Old Mar 15, 2005 | 07:36 AM
PrettyLude's Avatar
no you can't swap it
Old Mar 15, 2005 | 07:45 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">no you can't swap it</TD></TR></TABLE>
why not? a base model tranny would bolt up all u need is a base intermediate shaft to go with the tranny and i think your goin to need a base ecu and maybe even cv axles as long as its from a 5th gen
Old Mar 15, 2005 | 08:27 AM
Daemione's Avatar
Default Re: (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">why not? a base model tranny would bolt up all u need is a base intermediate shaft to go with the tranny and i think your goin to need a base ecu and maybe even cv axles as long as its from a 5th gen</TD></TR></TABLE>
You just need a base intermediate shaft & a custom bracket to mount it. SH axles work fine, as does the SH ECU - although you'll have the ATTS light unless you pull the bulb.
Old Mar 15, 2005 | 08:33 AM
fastfu's Avatar
no a base gearbox won't bolt on because the type s has a different block and the gearbox bolts are in different places
Modified by fastfu at 11:57 AM 3/15/2005
Old Mar 16, 2005 | 06:58 AM
Default Re: (fastfu)
so what you are saying is that H22A8 can't be swapped with any other H22Ax unless the gearbox is swapped over as well?? i thought that all the H22As were identical (except for internals).
Old Mar 16, 2005 | 07:11 AM
raylude's Avatar
Default Re: (The Wizard of Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfu &raquo;</TD></TR><TR><TD CLASS="quote">no a base gearbox won't bolt on because the type s has a different block and the gearbox bolts are in different places
its been done they bolt up i seen a write up on it some where all you needed was a custom braket for a base intermediate shaft
Old Mar 16, 2005 | 07:30 AM
http://ian.clendaniel.net/gallery/noatts doesn't work... & i have searched and searched and found no other writeups and pictures.
any other links you can provide so that i can take it to my garage and have them do the work.
Old Mar 16, 2005 | 07:48 AM
Shakes's Avatar
space cadet
https://honda-tech.com/zerothread?id=1081801
the base block has different mounting holes then the SH / type S block.
You would just need a base transmission from any H series prelude and then fab a bracket for the intermediate shaft.
also any H series intermediate shaft will work. i am now running an H23 tranny and intermediate shaft with 5th gen SH half shafts on a 2000 base block.
in all other aspects it will work. to rid yourself of the ATTS light just pull the ATTS ECU.
if anyone doubts this kiss my ***, because i did it.
all you have to do though if you want is to pull the ATTS ECU and the ATTS Fuse and you will be able to drive it like normal
Modified by Shakes at 10:02 AM 3/16/2005
Old Mar 16, 2005 | 08:10 AM
Default Re: (Shakes)
thanks a bunch dude...
one more request: any pictures of the custom bracket & fuse location ? havent found an online SH manual as yet & dont want to pull the wrong fuse out and drive home i've read that its rated 20
Old Mar 16, 2005 | 09:02 AM
Shakes's Avatar
space cadet
for the fuse it should be either under the hood in the upper left hand corner, or under the drivers side (in the US at least). the fuse pannels will have it labled and say ATTS.
for a custom bracket i do not have any pics, but you will need to figure a way to attach the three bolts of the intermediate shaft to the left two holes on the type S block. just use your imagination, a plasma cutter and a welder and you should be good to go.
Old Mar 16, 2005 | 11:36 AM
PirateMcFred's Avatar
https://honda-tech.com/zerothread?id=760082
Pirate
Old Mar 19, 2005 | 03:14 PM
Default Re: (PirateMcFred)
picked up the lude, read the fault codes... got ABS and ATTS (78,79) codes but could not find any references to those in the fault codes list. then reset the system and the fault hasnt come back... done 200 miles testing on different roads and still no fault codes hopefully it wont come back now... tyre pressure on the front was very low, 24psi. inflated it to 32 all around before the reset and everything seems to be working perfectly for now.
got a bit of hesitation problem, which is part cured with new spark plugs... got to investigate that now
Old Mar 31, 2005 | 12:34 PM
fastfu's Avatar
glad it turned out good
Old Mar 31, 2005 | 02:23 PM
vinuneuro's Avatar
you have a very nice collection of cars.
mattm868
Dec 15, 2006 10:55 AM
prelude1911
Feb 14, 2006 08:53 AM
99shRIGGS
Jan 13, 2005 09:51 AM
blackludeH22
Apr 9, 2004 07:59 PM
crxrich_kid
Oct 29, 2003 09:01 AM
