accord squeeels making right turns
Old Mar 15, 2005 | 12:35 AM
aasaa666's Avatar
Default accord squeeels making right turns
my 95 accord squeels making right turns. Not all right turns though, only the ones where im turning right and I can feel the body roll to the left. If Im turning slow I wont hear the squeel. Its not the tires either because it sounds different
Old Mar 15, 2005 | 06:43 AM
InOneAccord's Avatar
Default Re: accord squeeels making right turns (aasaa666)
make 3 lefts instead
Old Mar 15, 2005 | 07:41 AM
jdmaccordfreak's Avatar
check the ball joint
Old Mar 15, 2005 | 11:26 AM
Filthy Focker!'s Avatar
Default Re: accord squeeels making right turns (jdmaccordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaccordfreak &raquo;</TD></TR><TR><TD CLASS="quote">check the ball joint</TD></TR></TABLE>
You sure about that???
Could be that your tires are shot?
Could be that you are turning to fast?
How about tire pressure?
fs
Old Mar 15, 2005 | 11:36 AM
ridexstraight's Avatar
Default Re: accord squeeels making right turns (filthy_shovel)
yea my 94 accord squeekes up front bad also, on the rite side when i hit a bump or turn at all????
Old Mar 16, 2005 | 10:45 AM
flight50's Avatar
Default Re: accord squeeels making right turns (ridexstraight)
have you checked your axle?
Old Mar 16, 2005 | 04:22 PM
hotaccord243's Avatar
Default Re: accord squeeels making right turns (flight50)
you wanna lift the car up and give both wheels a good nice shake motion left then right a couple times and if it seems loose (compared to the other side) it would be the ball joint, i would try that first, or check the brake pads are they low and the early warning is scraping against the rotor? you should check that axel also!
Modified by hotaccord243 at 8:06 PM 3/16/2005
Old Mar 16, 2005 | 06:53 PM
zumiez007's Avatar
sounds like eithor your axel or CV joint is going.
Old Mar 16, 2005 | 06:56 PM
The_Todd's Avatar
Farts in the shower
First thing I would do is check your p/s level....if you are low on level it will make a squeeling sound. Go from there because it's the easiest and cheapest to look into, if that doesn't work out then I would suggest cv boots and also axle/spring/shock assemblies.
Old Mar 16, 2005 | 07:41 PM
ExiledinIN's Avatar
Default Re: accord squeeels making right turns (.ken)
Before you check the axles and other suspension parts, how is your pads? My integra used to squeak then grind when making left turns. Took the tire off and saw that my pads were worn down. Replaced the pads, and everything was fine.
Old Mar 16, 2005 | 08:18 PM
NBPcivic07's Avatar
Default Re: accord squeeels making right turns (ExiledinIN)
loose belt perhaps
Old Mar 17, 2005 | 12:19 AM
aasaa666's Avatar
My brake pads are fine they are as thick as the length of one of my finger nails.
Old Mar 17, 2005 | 05:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">
fs</TD></TR></TABLE>
Old Mar 17, 2005 | 05:59 AM
jakeiscool's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like eithor your axel or CV joint is going.</TD></TR></TABLE>
Old Mar 17, 2005 | 08:54 AM
aasaa666's Avatar
I check my tire pressure once every other week.
what does it mean to have shot tires?
and how fast would you consider a fast turn? I can tell you how I take most turns. I turn then I gas the last 2/3s of the turn.
Old Mar 17, 2005 | 08:56 AM
aasaa666's Avatar
Default Re: accord squeeels making right turns (JakeIsCool)
I'll consider that and try to get a shop to look at that.
Old Mar 17, 2005 | 08:59 AM
puma1077's Avatar
what about ur rear drum pads?
Old Mar 17, 2005 | 11:48 PM
aasaa666's Avatar
Default Re: (puma1077)
Im sure of it that the sound is coming from the front and not somewhere from the rear. are you hinting that it could also be my ABS taking action without me knowing it?
Old Mar 18, 2005 | 04:51 AM
b204dr's Avatar
sounds like a bad axel like 2 other people here have said - other wise wheel bearing - when your putting pressure on that side of the car it forces that axel/bearing to work harder causing it to squeel- bearning might just need to be lubes - if its the axel- might need a new boot - or the spindle might be shot
uberEFtuner
Dec 4, 2013 03:14 PM
honda671
Nov 17, 2007 02:59 AM
krytoi
Feb 16, 2007 03:50 PM
rscawley
Mar 21, 2002 07:35 PM
