Car won't start..cranks fine..electrical problem???
Old Mar 15, 2005 | 12:24 AM
wilrock's Avatar
Default Car won't start..cranks fine..electrical problem???
Lately my car hasn't started due to the warmer weather...as soon as night hits and the car cools down it starts just fine...it cranks and everything but does not start. Friends say it sounds like an electrical wire is loose somewhere..also sounds like everything is fine but no fuel is goin to the engine...anyone know whats goin on???
Old Mar 15, 2005 | 07:37 AM
PrettyLude's Avatar
main relaysih?
Old Mar 15, 2005 | 10:45 AM
chucksnee's Avatar
Default Re: (PrettyLude)
Need to know what year, model and so on.................
Old Mar 15, 2005 | 10:56 AM
wilrock's Avatar
Default Re: (chucksnee)
94 prelude si..if it is the main relay how do i replace it?
Old Mar 15, 2005 | 12:25 PM
PrettyLude's Avatar
its underneath the dashboard on the driver side, held on by 10mm bolts, its kinda cluttered down there, so make sure you grab the right one
Old Mar 15, 2005 | 01:44 PM
T-King's Avatar
Yea the relay on the 4th gen is exactly strait up from the brake pedel when you look under the dash and it has a orangeish, brownish plug with the same color piece where the plug connects.
Old Mar 15, 2005 | 02:37 PM
nslude's Avatar
Default Re: (HondaLude92)
pull it out and open it up..i think mine was grey......u can resolder any cracked joints in there...when they get hot the cracks will open and lose contact...
Old Mar 16, 2005 | 07:26 AM
wilrock's Avatar
Default Re: (nslude)
thanks i'm going to check out the relay today and i'll post my results later on
DeeJaaY209
12
Sep 26, 2013 12:02 PM
teg-ga
Nov 17, 2004 08:20 AM
ludicrous
Jun 17, 2004 08:20 PM
fe519
Sep 17, 2003 04:34 AM
