gsr swap into eg rear mount bracket
i'm swapping in a 1994 gsr swap into a 1994 si. I have the 94 si rear middle rubber mount with energy motor moumt inserts and i have a 1999 b16a2 rear mount bracket.
I was told that i needed a gsr rear mount bracket, can i just use the 1999 b16a2 bracket??? will it fit right????????
Modified by bboylito at 10:57 AM 3/15/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito »</TD></TR><TR><TD CLASS="quote"> i'm swapping in a 1994 gsr swap into a 1994 si. I have the 94 si rear middle rubber mount with energy motor moumt inserts and i have a 1999 b16a2 rear mount bracket.
Nope. The 99 Si one is shorter. You need the one off the 94+ Integra.
</TD></TR></TABLE>Nope. The 99 Si one is shorter. You need the one off the 94+ Integra.
i'm about to trade someone my si bracket for their gsr bracket
HOW CAN I TELL THE DIFFERENCE?? like how do i know whether or not its an h22, d series, b series etc...
thanks for the reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito »</TD></TR><TR><TD CLASS="quote">i'm about to trade someone my si bracket for their gsr bracket
thanks for the reply</TD></TR></TABLE>
Set the two mounts side by side and you WILL see the difference between the two. The Si is "shorter". Other then that, they look the same.
sanegb16
Sep 5, 2007 01:41 PM
