driving on a previously tuned hondata. not my specs...
Old Mar 14, 2005 | 08:41 PM
1.8's Avatar
1.8
Default driving on a previously tuned hondata. not my specs...
i gotta take my car to get it tuned. will i be ok if i run my ECU with hondata that was previously tuned with different specs? all i know is it's tuned for 550s and a built LS/VTEC motor. i only have 440s with stock motor. what can i do?
can i use a automatic LS ECU or something just to get there? it's a LS motor. is there anyway to erase the previous specs?
Old Mar 14, 2005 | 10:58 PM
1.8's Avatar
1.8
Default Re: driving on a previously tuned hondata. not my specs... (1.8)
help...
Old Mar 14, 2005 | 11:01 PM
SOHC_MShue's Avatar
no you can't run on those maps. You will probably run lean as **** considering that motor was tuned for 550's and you only have 440's. For the 550's the fuel values have to be scaled down lower than the 440's.
Old Mar 14, 2005 | 11:45 PM
1.8's Avatar
1.8
Default Re: driving on a previously tuned hondata. not my specs... (SOHC_MShue)
can a tuner scale it down or do anything so i can drive it to get it tuned?
Old Mar 14, 2005 | 11:49 PM
SOHC_MShue's Avatar
yes just use the option in hondata to rescale the maps for the smaller injectors. It should be enough to get you to the tuner. I wouldn't push it on those maps though..in fact its probably just to make a basemap for your setup rather than use that guy's maps.
Old Mar 14, 2005 | 11:55 PM
1.8's Avatar
1.8
this is something i can do myself?
Old Mar 15, 2005 | 06:43 AM
SOHC_MShue's Avatar
you would need the hondata software and a burner.
lexruger
Engine Management and Tuning
Sep 29, 2010 09:55 PM
mkinpwrat12g's
Aug 31, 2005 10:41 AM
22boost
Nov 11, 2004 01:29 PM
