b16 valve lash torque?
Old Mar 14, 2005 | 07:23 PM
ernald711's Avatar
Default b16 valve lash torque?
okay it's for a 2000 si head. no one seems to kno the answer. i searched and found a post that stated 30ft lbs, then someone came back say'n it was 20ft lbs. anyone with a manual can find this out. i don't have one so can someone help me out. this is a repost from the civic forum, seems like those guys can't help me.
Old Mar 14, 2005 | 07:46 PM
3.504's Avatar
Default Re: b16 valve lash torque? (ernald711)
its 20nm (14lb/ft) for the adjuster lock nuts. also says the head should be under 100*F when adjusting
incase there was any question, lash spec is 0.15mm-0.19mm(0.006-0.007") for intake and 0.17mm-0.21mm(0.007-0.008")exhaust.
got this info from alldata which is info released from honda.
Old Mar 14, 2005 | 08:27 PM
ernald711's Avatar
Default Re: b16 valve lash torque? (3.504)
thanks
cranker
Apr 19, 2010 06:53 PM
speedchoppy209
Jul 21, 2006 07:28 AM
andhatch84
Jun 15, 2005 09:59 PM
ernald711
Mar 14, 2005 08:41 PM
ernald711
Mar 14, 2005 08:04 PM
