weird cooling issue
ok..since march 6th my car has been sitting in a heated garage...i started it and let it run until fully warmed up tonight ..i was looking things over smoking a cigarette and i noticed i smelled burning coolant...but no leaks..i checked all of my coolant lines on the back of the intake manifold and firewall and everything seemd fine...i felt the radiator and it was hot but not burning hot..the fan did not come on yet but i think it was to early for that..i felt both the upper and lower rad hoses and they both were super hot and they both looked a little "bloated" espically right where the hose goes into the head on the top one..both hoses were completly pressurized and bloated looking...this got me worried so i shut it off and decided to figure this out..the idle started loping when it got warm too..any ideas?
b16a in a eg
b16a in a eg
and youre smelling coolant?
check underneath the driverside dash and feel around the floor to see if it feels damp.. or maybe if you can see underneath, there are two bronzish looking pipes, sometimes you can see if something is leaking from them...
maybe your heater core is leaking?
this **** is bothering me..i allready have a oem thermostat...enough coolant to do a flush...im gonna pick up new hoses tomorrow after work..headgasket is new..oil is clean..not mixed with coolant
i did smell a little coolant..but not inside the car...under the hood only..and there arent any leaks...the floor is dry...the sensor on the back of the intake manifold next to the throttle body made a weird buzzing sound but only when i gave it a little throttle(about 500 rpm over idle)..but it went away when it went back to idle(900rpm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy del sol »</TD></TR><TR><TD CLASS="quote">and youre smelling coolant?
maybe your heater core is leaking?</TD></TR></TABLE>
Umm...maybe, but if you've ever done a heater core on an EG, you'd know that you can't see where the lines go into the case. They're completely hidden from the interior until you remove the entire dash, dash subframe assy, and heater case...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Who Said »</TD></TR><TR><TD CLASS="quote">maybe its a leaking head gasket and you smell the coolant after its being burned in the exuast system. try a cylinder leak down test on all 4 cylinders</TD></TR></TABLE>
He said its a new head gasket, so I doubt that is the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
He said its a new head gasket, so I doubt that is the problem. </TD></TR></TABLE>
It still may be a head issue. Did you get the head checked, to make sure it wasnt warped?
i would double check...wouldnt hurt and it would elimnate that as a cause. if it has reently been done some one could have made a mistake
dbailey
11
Jan 30, 2020 04:27 AM
xolk88
10
Mar 18, 2010 05:18 AM
jdm_dc_fan
Jul 30, 2008 06:53 AM
Razr2
Jan 16, 2008 04:59 PM
