power steering is low !!!
Old Mar 14, 2005 | 05:18 PM
nichols_si's Avatar
Default power steering is low !!!
hey what PS fluid should i use anything thats reccommened i dont have my manual lost it .. help me out guys thank you
its a 92 eg si hb z6 motor
Old Mar 14, 2005 | 05:23 PM
coupe_hybrid's Avatar
Default Re: power steering is low !!! (nichols_si)
Well look for the powersteering fluids that say made for hondas.
Old Mar 14, 2005 | 05:39 PM
nichols_si's Avatar
least u replied, thanks ttt
Old Mar 14, 2005 | 06:16 PM
JibOnALib's Avatar
Default Re: (nichols_si)
I don't know if you thought he was being sarcastic or not, but just to clarify things up it actually will say "Power Steering Fluid, for Honda Vehicles" on the cover of the bottle. You're supposed to use a special fluid, if you go to like Jiffy Lube they'll probly top it off for you for free, If not just try a parts store.
Old Mar 14, 2005 | 06:21 PM
Padawan's Avatar
Darth ModerVader
Default Re: (JibOnALib)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JibOnALib &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if you thought he was being sarcastic or not, but just to clarify things up it actually will say "Power Steering Fluid, for Honda Vehicles" on the cover of the bottle.</TD></TR></TABLE>
Correct. I prefer genuine Honda fluid, but any fluid marked "For Honda & Acura vehicles" will be fine, and you should be able to find it at your local auto parts store. Here's an example photo just for reference:
Old Mar 14, 2005 | 06:31 PM
dohcVTECeg2's Avatar
go to autozone they have a bottle of it for like 4 bucks its called honda power steering fluid
Old Mar 14, 2005 | 09:16 PM
JarvisW's Avatar
Sol to Sol
Default Re: (dohcVTECeg2)
Mine was very low the other day. I put Honda PS fluid in it, and so far it hasnt seemed to use any more fluid.
Is there any reason for it to be almost all the way gone last week, but now not using any fluid now? Like why was it gone in the first place, and why hasn't it shown any fluid loss now?
Thanks
Old Mar 14, 2005 | 10:08 PM
Bond's Avatar
Default Re: (JarvisW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JarvisW &raquo;</TD></TR><TR><TD CLASS="quote">Mine was very low the other day. I put Honda PS fluid in it, and so far it hasnt seemed to use any more fluid.
Thanks</TD></TR></TABLE>
Probably not the right type. It must be DOT 3 Honda PS fluid. I prefer to go to Honda and buy the real stuff (even if it costs more). After topping of mine last year, it hasn't needed it since. Get the real stuff
Old Mar 14, 2005 | 10:18 PM
Alstare's Avatar
Default Re: (Bond)
What's the difference between the "Honda PS Fluid" and the regular dot 3 **** that everyother car in the world uses and is readily availble? Fact's preferably, not "cause I prefer"...Thanks
Old Mar 15, 2005 | 08:11 AM
flood's Avatar
Default Re: (Alstare)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alstare &raquo;</TD></TR><TR><TD CLASS="quote">What's the difference between the "Honda PS Fluid" and the regular dot 3 **** that everyother car in the world uses and is readily availble? Fact's preferably, not "cause I prefer"...Thanks</TD></TR></TABLE>
Your vehicle requires Honda Power Steering fluid as well as Honda manual transmission fluids. This means fluids from Honda, not an aftermarket manufacturer. Honda is a very well made vehicle, and proper care using the correct fluids for all applications will help to isure a long life from the vehicle.
The reason that honda's use their own power steering fluid is because if you use anything else in there it will eat away and disolve the o-rings and seals in the power steering system. Honda specially formulates their power steering fluid for their cars, exclusively.
Same with coolant. It is silicate free made for their aluminum engines.
Besides, there isn't a good reason NOT to.
Old Mar 15, 2005 | 02:32 PM
JarvisW's Avatar
Sol to Sol
Default Re: (flood)
So the coolent is also Honda propriatary?
Eh, I'm beginning to feel like I bought a Mac or something lol.
J/K
I just replaced the radiator last year, but I only put regular half and half in it. Should I flush and fill it?
Old Mar 15, 2005 | 03:07 PM
Bond's Avatar
Default Re: (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">
Besides, there isn't a good reason NOT to. </TD></TR></TABLE>
Thanks for the back up! Clearly if you do not know the difference between Honda PS fluid and aftermarket DOT 3 PS fluid, then maybe you should look into buying a Ford Focus. The point I made before and what flood said, is that with the real stuff you do not need to "top it off" as much. The reason you need to keep topping it off is because it is going into your seals and evaporating. Get the real stuff
Old Mar 15, 2005 | 03:30 PM
Alstare's Avatar
Default Re: (Bond)
Heh...
I'm a GO Honda fan myself, but this honda only fluids thing has gotten out of hand...
You'd think a company that does nothing but focus on there specific fluid would know a thing about it aswell, and not make something that will DESTROY your honda if it says it will work with them.
I geuss companies like Mobile1 who make all the oils for most european exotic cars from the factory should learn a thing or two from Honda on fluids...
But like ya said to each there own.
Ask most pro racers and people who have 300,000km's+ on there honda beaters if they use only honda fluids. I think you'll be surprised. And most people on here are far from stock anymore so what was designed for stock might not work anymore.
At any rate, go Honda..
Old Mar 15, 2005 | 03:38 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alstare &raquo;</TD></TR><TR><TD CLASS="quote">Heh...
Other companies do not care if it is the same; if they put made for Honda's then poeple will buy it. It is always better to buy things that are the same name brand and are designed to go with that car. I do agree though that this discussion is getting a little heated. It's just PS fluid. Let's bring it down a notch.
Old Mar 16, 2005 | 06:38 AM
flood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alstare &raquo;</TD></TR><TR><TD CLASS="quote"> You'd think a company that does nothing but focus on there specific fluid would know a thing about it aswell, and not make something that will DESTROY your honda if it says it will work with them.
I geuss companies like Mobile1 who make all the oils for most european exotic cars from the factory should learn a thing or two from Honda on fluids... </TD></TR></TABLE>
Dude...its MOBIL 1
Why don't you show us more about how much you know? Teach us oh great one!
And most racers use a brake fluid with a higher boiling point than
DOT 3 (401/284)
DOT 4 (446/311)
Old Mar 16, 2005 | 06:40 AM
SnowSurfer's Avatar
Default Re: (flood)
just pull the power steering out, you dont need it anyway.
Power steering is for babies
but on a side note, use the recommended honda stuff from the honda dealer...
kitg
Apr 13, 2015 08:01 AM
DOHCon15s
Apr 6, 2007 10:04 PM
Brian-Brian
Oct 25, 2003 02:29 AM
leorlee
Sep 25, 2003 04:39 PM
