custom exhaust pipe on b18 swap.. help needed w/ o2 sensor
Old Jan 23, 2002 | 03:15 PM
TurboBumblBee's Avatar
Default custom exhaust pipe on b18 swap.. help needed w/ o2 sensor
ok, just got the swap all done and installed into 94 civic coupe w/ apexi n1 full catback.. the headers from the b18c1 are about 5 inches to short so i know we need a custom pipe for that..
can i put the o2 sensor on the custom pipe cause the plug is on the bottom of the engine?
Old Jan 23, 2002 | 04:15 PM
deepnite's Avatar
Default Re: custom exhaust pipe on b18 swap.. help needed w/ o2 sensor (95CivicEX)
yup..ive done that on a OB II civic
Old Jan 23, 2002 | 04:20 PM
DIZASTICAL's Avatar
when i dropped a b18 in my 92-95 coupe that i had the header was also very short . i spent $240 for random technologies to custom make me one with a hole for the o2 sensor . two weeks later the cat rattled like crasy and i had to punch it out because all the honey combs broke . dont go this route . have a shop make you a pipe with a fitting for a o2 sensor . hope this helps !
Old Jan 23, 2002 | 04:22 PM
Joe_M's Avatar
Default Re: custom exhaust pipe on b18 swap.. help needed w/ o2 sensor (DIZASTICAL)
Use an Si header..... bolts right in and has a bung for the o2 sensor in it.
Joe
eLeCtRoNSi00
Mar 1, 2005 07:25 AM
ebpcivicsi1234
Jan 22, 2005 08:55 AM
leonard1818
Nov 29, 2004 09:05 AM
BanEL
Nov 22, 2003 12:26 PM
