ignition output signal Code 15
i just did a b16 swap to my 90 crx i replaced the dash harness and the engine harness. both are 90 crx si harnesses. i went to fire it up and the ecu says code 15. i as so has a new distributor but it still says code 15 can you help get my car running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDAofPOKY »</TD></TR><TR><TD CLASS="quote"> the ecu says code 15. i as so has a new distributor but it still says code 15 can you help get my car running.</TD></TR></TABLE>
Did you replace the ecu?
hans stoner
Oct 22, 2006 07:13 AM
