One more question about Crome
Old Mar 14, 2005 | 04:01 PM
Nisif's Avatar
Default One more question about Crome
For an OBD-0 ecu, can crome eliminate the need for the secondary O2 sensor? I was planning on running only a heated 4-wire O2 sensor for the primary since the header bung is way down on the collector. But I am going to have to run the secondary O2 sensor, if so, any suggestions where to place the bung for it?? Thanks
Old Mar 14, 2005 | 04:57 PM
Nisif's Avatar
Default Re: One more question about Crome (Nisif)
Bump for Crome Users
Old Mar 14, 2005 | 05:11 PM
rice4life's Avatar
you would probably get a better answer at pgmfi.org, not too many crome user with obd0 in here. i don't know now you are planning on running a heat o2 sensor with obd0 ecu. are you running a separate heater controller for the o2 sensor. if you are going to keep the sensor setup like oem, than they have to be from cylinder 1-4 and 2-3, if not your car will run like crap at part throttle. if you are just going to run 1 o2 sensor, then just hook both o2 wires from the ecu to the one sensor, that's how i had my setup on my boosted b16a with pr3 ecu. i just used one single wire 02 sensor and mount as close to the down pipe as possible to get enough heat.
Old Mar 14, 2005 | 07:20 PM
Eddiebx's Avatar
considering crome is based off p30 code, and is only for obd1 ecus, I highly doubt its going to do you any good. You should go over to the pgmfi forum and read up more
Old Mar 16, 2005 | 08:53 PM
del_orson's Avatar
Default Re: (Eddiebx)
you should ask questions on the pgmfi.org forum
Contender25
17
May 3, 2006 09:04 PM
rice4life
Jun 26, 2003 03:39 PM
filetofit
Feb 16, 2003 01:41 PM
gtpilot
Dec 12, 2002 12:27 PM
