Need help with TRANNY
Old Mar 14, 2005 | 03:54 PM
HatchKid12's Avatar
Default Need help with TRANNY
Well my clutch went out so i replaced it like a good owner should do..
Now the tranny is gone the person said.
I dont know if this is true(talking about the tranny), but when its in neutral it like stalls and plus it doesnt even go in gear its just...all loose and what not.
Even try lifting to hatch to change gears underneath, no work...
Is it worth it getting a new tranny, or mabe there is another route i can take, idk just need a little help
BTW its a 1990 honda civic ZC swap
Old Mar 14, 2005 | 04:00 PM
FalkenSiR's Avatar
Default Re: Need help with TRANNY (HatchKid12)
What tranny are you using?
Well, no 1 if its loose its probably you bushings and if its hard to get into gear usually its the throwout bearing.
Maybe your bushings are SO fucked that it will be hard to get into gear. And also, is this present in all gears? Like neutral-4th?
Old Mar 14, 2005 | 04:07 PM
HatchKid12's Avatar
It goes in if u play with it enough..or like push it in really hard..but all 1-5 gears+ reverse are messed up, how can i check if its my bushings...
Plus its an LS tranny i think... i know B tranny and D series motor dont mix...but thats what the owner said when i bought, i didnt know much about cars then ,
I still think its an LS tranny if i new where to look or new how to identify them i would tell ya.. but i dont lol
I dont think its the throw out bearing cause thats brand new with clutch
Old Mar 14, 2005 | 04:40 PM
HatchKid12's Avatar
bump for me....
plus.... how much do you think my car can go for with the bad tranny?
Old Mar 14, 2005 | 05:01 PM
sit220's Avatar
if u have a zc swap then is a stock si trany d series not an ls
zc still a d serie
Old Mar 15, 2005 | 03:57 PM
HatchKid12's Avatar
Default Re: Need help with TRANNY (sit220)
bump for a lil more info
WestSideRain
Jul 5, 2009 08:48 PM
ej8_vtec
Aug 18, 2006 02:57 PM
baked_beanz
Aug 14, 2005 10:19 AM
mrpeabody
Jun 13, 2003 11:20 AM
