rear end help
Old Mar 14, 2005 | 02:41 PM
red94hatch's Avatar
Default rear end help
had an accident and need help replacing the whole right rear end (sus.) needed to know if this is something that i can do myself, heard that it was easy.....has anyone done this befor? my biggest area of concern is gettin the shock out and spring never done it befor. all suggestions are greatly appreciated !!!!!!
Old Mar 20, 2005 | 11:58 PM
longbeachpurplecivic's Avatar
Default Re: rear end help (red94hatch)
you need to replace the entire thing or just the spring/shock?? two bolts for brake line. one bolt for LCA. two bolts in the trunk area that holds up the shock. couple bolts under the body that holds up the trailing arm i think.. and you gotta take out the cable too.. camber kit too.. am i missing anything else anyone??
Old Mar 21, 2005 | 12:02 AM
Ls_V_TurboSi's Avatar
Default Re: rear end help (longbeachpurplecivic)
Did it yesterday.. Peice of cake.. I've done it about 20 times though... If you're replacing the whole trailing arm that kinda sucks becuase you gotta deal with the ebrake cable but if you're just replacing little bits and peices it should be cool... Theres only about 7 bolts that hold the whole thing on.. relatively simple task
Old Mar 21, 2005 | 12:05 AM
Default Re: rear end help (Ls_V_TurboSi)
so did i name all the right bolts
Old Mar 21, 2005 | 12:12 AM
kinda sorta.. Its 2 NUTS in the trunk.. Theres 2) 14 mm bolts that go into the LCA.. One bolts to the frame of the car and the other one goes through the strut. Then theres the 2 17mm bolts that hold the trailing arm upright then the last 14 mm at the end of the trailing arm that you used to adjust the alignment.. Then the 2 14's that are up top (the ones you change if doing the camber kit trick and last but not least th 2 12's that hold the ebrake cable in place... I think thats it
Old Mar 21, 2005 | 10:39 AM
alright man so let us know how you did
BoostedTeg97
Suspension & Brakes
Jan 21, 2010 02:05 PM
josh green
Suspension & Brakes
Sep 27, 2008 06:01 PM
tdubbebawllin
Sep 10, 2008 07:24 PM
stripes777
Aug 11, 2008 07:50 PM
Soda Popinski
Mar 30, 2004 05:18 PM
