95 accord ex automatic won't shift gears?????
Old Mar 14, 2005 | 02:23 PM
Big Money D's Avatar
Default 95 accord ex automatic won't shift gears?????
it will just keep revving till redline and won't shift any ideas??
thanks
Old Mar 14, 2005 | 02:25 PM
BaddMo2002's Avatar
did u check your tranny fluid? any check engine lights or d4 flashing? Any prior problems?
Old Mar 14, 2005 | 02:28 PM
Default Re: (BaddMo2002)
tranny fluid is fine no check engine lights no nothing strange....
Old Mar 14, 2005 | 04:16 PM
raceACCORDingly's Avatar
mine did the same, the clutch packs inside took a ****. so basically its dead.
it was slipping during shifts before right?
Old Mar 14, 2005 | 04:53 PM
vc's Avatar
vc
Default Re: (raceACCORDingly)
maybe your in L and not D? =/
Old Mar 14, 2005 | 08:17 PM
BaddMo2002's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">mine did the same, the clutch packs inside took a ****. so basically its dead.
it was slipping during shifts before right?</TD></TR></TABLE>
exactly..in order for the clutch packs to die...you must have had some symptoms before. If no symptoms...it could be a bad transmission computer.
Old Mar 15, 2005 | 07:31 AM
jdmaccordfreak's Avatar
its dead. same thing happened when i had a 94 accord.
Old Mar 17, 2005 | 07:38 PM
accord0494's Avatar
Default Re: (jdmaccordfreak)
is this problem fixable cause my car does the same thing only at 5500rpms and its really annoying, it just like bogs out, and you have to let off the gas and kick her back down again, for it to come out of it... it sucks especially on the highway when your trying to pass grandma and can't make it by her and have to pull back in!!
i know its no race machine, but i don't think i ever had it going anymore then 120kms\h so like 80mph, sure that's plenty fast, but when you want to pass someone and can't it sucks!! haha
Old Mar 18, 2005 | 07:27 AM
dead x leg's Avatar
Default Re: 95 accord ex automatic won't shift gears????? (Big Money D)
i had the same problem w/ my accord. when i traded it in at honda, they said the transmission was gone.
Old Mar 18, 2005 | 11:49 AM
THEROPE's Avatar
Default Re: 95 accord ex automatic won't shift gears????? (dead x leg)
i just had the same problem its shot,
just took the tranny off and im converting to a 5speed
Old Mar 18, 2005 | 04:51 PM
Default Re: 95 accord ex automatic won't shift gears????? (THEROPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEROPE &raquo;</TD></TR><TR><TD CLASS="quote">i just had the same problem its shot,
just took the tranny off and im converting to a 5speed </TD></TR></TABLE>
i did the same thing a year or two ago.
Old Mar 18, 2005 | 05:22 PM
dli's Avatar
dli
same thing happened to mine, i had mine swapped out, and on the new transmission, i had to keep topping off the tranny fluid or else it'd do the same damn thing. it's annoying as ****. i think one of the seals are gone on my tranny. a bloody shame. Good luck with you, my transmission cost me 700 cdn. ouch
masterkill455
Feb 20, 2009 10:37 AM
amh0001
May 29, 2005 08:28 PM
accord0494
Nov 8, 2004 05:34 PM
flrdaccrd
Jan 7, 2003 09:41 AM
