Removing tuned JRSC. Can hondata be ran with a stock setup?
Old Mar 14, 2005 | 02:05 PM
spidermancivic's Avatar
Default Removing tuned JRSC. Can hondata be ran with a stock setup?
Im replacing my usdm b16a2 shortblock with a usdm b16a3 shortblock due to bad ringlands. Im not going to keep the JRSC back on. Plan on slapping on a t3/t04b instead.
In the meantime, can my tuned hondata and RC 550s still be used on the stock setup? I really dont want to go through the hassle of switching the fuel management setp back to stock, and then, having to reswitch back over to the hondata and 550s when the t3/t40b goes in.
Old Mar 14, 2005 | 03:08 PM
Dunc's Avatar
BCICAN
Default Re: Removing tuned JRSC. Can hondata be ran with a stock setup? (spidermancivic)
if it was tuned with those on there, then yes you can keep it. You'll just be driving in the non-boost sections of hondata.
Old Mar 14, 2005 | 04:49 PM
Default Re: Removing tuned JRSC. Can hondata be ran with a stock setup? (Dunc)
thats what i was thinking.
Old Mar 17, 2005 | 12:30 PM
Spunkster's Avatar
You can do that, but the AF ratios will be all wrong. It is a completely different manifold and there is no longer an egg beater in between the head and the throttle body heating up the intake charge. I assure you the car will run differetnly. If you do it, drive very conservatively.
Modified by Spunkster at 4:37 PM 3/17/2005
Ldo
Engine Management and Tuning
Sep 3, 2009 12:15 PM
vactor
Sep 15, 2002 05:14 PM
InfamousRS
Jun 27, 2002 04:47 AM
nerdish
Jul 12, 2001 12:00 PM
