HELP WITH O2 sensor
okay i basicly i failed my emmisions, i got a 96 civic dx with a b20b motor non vtec, 96-99 acura ls ecu, obd 2, and hre are the fault codes:
overall obd result: fail
fault code result: fail
fault codes: po171, po141
*po141: o2 sensor heater circuit mal function (bank 11 sensor2)
*po171: system too lean (bank 11)
the one im worried abotu right now is the o2 sensor 1, also my check engine lights not on too
plz tell what u think it might be replace sensors or what else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20runner »</TD></TR><TR><TD CLASS="quote">
Did you splice a new O2 sensor in or anything? Likely your o2 sensor failed and now you need a new one. Also not reading correctly and causing you to lean out? :\
Is it an OEM original o2 sensor!? If it is, just replace it, its obviously malfunctioned on you and needs replacing.
Ok, what I'm really trying to say is..........your o2 sensor is dead and you need a new one.
In other words..................replace the o2 sensor.
id go oem. got mine off ebay from sparkplugsource i think and it cost me only 60 dollars i think after shipping
when 02 heater sensor is fried like what happened to me, it throws a code, mine ran extra rich tho... check engine light should have come on... use a paper clip and read ur codes anyway.
passenger side kick panel... remove the plastic cover, u will see a 2 wire plug (right beside the ECU), use a paper clip or wire and stick it in both sides, connecting it, or u can buy an expensive harness to do the same thing
then turn ur car to the on position without starting it. watch the CEL to see if there are any codes present.. sometimes u will have codes even tho ur light is not on
cwf1988
May 26, 2008 12:58 PM
Integra_Boi
Oct 1, 2004 08:07 AM
