what cams for h22 turbo?
Old Mar 14, 2005 | 11:47 AM
bjfisher's Avatar
Default what cams for h22 turbo?
im gonna run 20lbs of boost on my h series and was wondering what cams i should go with.so far, crower cams have been suggested and to my suprise, type s cams.anyone have any personal experience with either or any suggestions on what i should end up using?if you need to know more of my setup to give you a better idea, lemme know what you need and i'll let you know , thanks in advance
Old Mar 14, 2005 | 12:01 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: what cams for h22 turbo? (bjfisher)
well skunk2 has turbo cams but dont know if anyone has used them befor
Old Mar 14, 2005 | 12:31 PM
bjfisher's Avatar
hmm yeah i guess thats the real question i have, how much better is crower stage 2 than type s, and is it worth it?whats the ups and downs?and who has this already?
Old Mar 14, 2005 | 12:47 PM
md23vtec's Avatar
Default Re: (bjfisher)
Stock cams are fine you can make awsome power with them on turbo . Just my 2 cents
Old Mar 14, 2005 | 12:48 PM
bjfisher's Avatar
over 500whp?
Old Mar 14, 2005 | 12:49 PM
AndyD's Avatar
Default Re: (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">Stock cams are fine you can make awsome power with them on turbo . Just my 2 cents</TD></TR></TABLE>
Exactly what I was going to say.
There is a blue Lude in a turbo magazine that I have making over 500whp on stock cams.
Old Mar 14, 2005 | 12:57 PM
Rad Racing's Avatar
Bart Taylor Look-alike
Stock are great for big FI setups. I use stock cams with a lot of Nitrous, works great.
Old Mar 14, 2005 | 01:32 PM
john d
Guest
Posts: n/a
Default Re: what cams for h22 turbo? (Rad Racing)
i use stock ones...
Old Mar 14, 2005 | 01:38 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjfisher &raquo;</TD></TR><TR><TD CLASS="quote">over 500whp?</TD></TR></TABLE>
YES
Old Mar 14, 2005 | 02:20 PM
h22 civic's Avatar
save your money for somthing else to make power stock is just fine 500 easy
Old Mar 14, 2005 | 02:25 PM
ludelvr's Avatar
agreed. Many people are using stock cams and making nice numbers at a lower psi. Save the money and put it else where and in the end if you absolutely feel that you want more out of your engine then pick them up, but I'd put them last on my list.
Old Mar 14, 2005 | 02:41 PM
fastludeh22's Avatar
Default Re: (ludelvr)
i have used stock and crower stage 2 t. ive seen stocks go 568 on a friends car.
i have never tuned the same engine w/both cams, but i have driven both on the same engine and its a big difference. it reved and spooled a lot better.
i dont see type-s being good, but i can be wrong...i guess if you can dial out the overlap.
talk to turbo sam he has used both also (stock and crower)
i usally say after 500 is when u should look into cams
Old Mar 14, 2005 | 03:01 PM
bjfisher's Avatar
ok cool i guess i'll just stick with stock for now and get some valves/springs/retainers and a nice port and polish to go with the str IM and 70mm tb
95whiteeg6
Jul 14, 2010 08:11 PM
bjfisher
Mar 30, 2005 10:57 AM
usdmcivic94
12
Jul 12, 2004 03:04 PM
Drum_Guru
Jan 20, 2004 05:41 PM
eg:R
Jul 22, 2003 01:31 PM
