H22 turbo cams...
Old Jan 12, 2004 | 10:32 AM
Drum_Guru's Avatar
Default H22 turbo cams...
hey, i was wondering what was a real good set of turbo cams for the H22... also, where do they stop making power in the rpm band and where do you guys shift?
Old Jan 12, 2004 | 11:55 AM
Alstare's Avatar
Default Re: H22 turbo cams... (Drum_Guru)
Everything I researched when building my motor pointed to running the stock cams. I ran Some Type-S cams prior but removed them when I rebuilt after reading all the reviews/suggestion for turbo cams.
Not too helpful but it's a start..
Old Jan 12, 2004 | 11:58 AM
Drum_Guru's Avatar
Default Re: H22 turbo cams... (Alstare)
thx man... who else? From what I understand, stock cams have overlap btw intake and exhaust... this would blow boost straight out the exhaust... that would suck... is this true?
Old Jan 12, 2004 | 12:51 PM
Alstare's Avatar
I don't know the exact specs, maybe a cam guru will chime in.
I heard the oem cams have very little overlap in comparison to most aftermarket cams, hence the recomendation to use them.
Alot of people making big h22 power #'s are running the stock cams, so atleast we know there decent.
Old Jan 13, 2004 | 08:53 AM
tunedbylorange.com's Avatar
from what we hear too.. the stock ones are fine....at our last dyno our cams were making power on the way to 8000 rpms, I think they will make power to 9k
Old Jan 13, 2004 | 10:05 AM
Drum_Guru's Avatar
Default Re: H22 turbo cams... (tunedbylorange.com)
kool... 1 less thing to spend money on... so where do you heavy turbo'd H22's shift (1/4 driving...)?
Old Jan 15, 2004 | 11:19 AM
Drum_Guru's Avatar
so you guys just change the cam gears... and where in the rpm band do you guys shift???
Old Jan 15, 2004 | 01:13 PM
nope we don't even have cam gears yet..Dennis shifts around 7500 to 8000k
Old Jan 15, 2004 | 01:30 PM
Alstare's Avatar
Same stock cam gears, power peaks around 7600rpm....
Old Jan 15, 2004 | 01:31 PM
JSMC's Avatar
hey but lets continue the discussion, I must change my camshaft for my h22 head, when I bought the engine it was disassembled (don't bother I bought it at a ridiculous price, less then 700$ with 2 head,...) and when I got it home it was raining out side, so some water got on the camshaft and now their's some spot of rust on it at first I was hesitating to change my camshaft, but now I must change them, so I tought why go with other stock ones when I can get better ones for some more $$
Old Jan 15, 2004 | 02:08 PM
Alstare's Avatar
Default Re: H22 turbo cams... (JSMC)
Use some scotch brite on the camshaft should take off any surface rust, if it's bad then your kinda sol. If you dead set on buying some aftermarket cams lookk for some "turbo" cams...
Old Jan 15, 2004 | 02:15 PM
JSMC's Avatar
ok i'll check if I can do anything with them, but I'm really sure they are useless!!, so i'll go check for which aftermarket company?? the engine is going to rev a lot so I don't want the cam to fail
Old Jan 16, 2004 | 11:47 AM
Drum_Guru's Avatar
what is a really good aftermarket cam maker? really reliable, blah blah... you know... I am sure almost any good company could grind out some coustum cams with 0 degree overlap and whatever size lobe you wanted...
Old Jan 17, 2004 | 10:17 AM
Drum_Guru's Avatar
bump for "a reply would be cool"
... who makes good coutum ground cams?
Old Jan 20, 2004 | 05:41 PM
chidoks's Avatar
i wonder how a type s intake cam with a regular h22 exhaust cam would work
95whiteeg6
Jul 14, 2010 08:11 PM
turboorsupercharger
Nov 23, 2009 12:25 PM
purpleh22
Jan 18, 2006 11:00 AM
bjfisher
Mar 30, 2005 10:57 AM
eg:R
Jul 22, 2003 01:31 PM
