mini me ecu Q
Old Mar 14, 2005 | 11:46 AM
menappi's Avatar
Default mini me ecu Q
which ecu should i use with a a6 bottom and y8 head? i wanted to keep it obd0 but i heard the pr3 doestn run good with z6/y8. could i get my ecu chipped so it acts like a p28 or something? or should i just keep my pm6 and get a vtec controlller. im on a budget but i want the car to run good. also, if i used a vtec controller on my stock ecu or another non vtec ecu, could i also use the vafc to do the 'hack' thing or tune my motor when i turbo it??????
Old Mar 14, 2005 | 02:06 PM
Mach69's Avatar
Default Re: mini me ecu Q (menappi)
Don't make the same mistake I did of going OBD-0 and running a vtec controller.
Here is the answer to your question: the ecu you should use is either PM6 or PG7. PR3 might work, but DONT use it, its set for dohc. Yes you can get a PM6 ecu chipped. You use the vafc to engage vtec, but whats the 'hack' thing?
Here is what I and you should do: Switch to OBD-1. Get a P28 ecu, a conversion harness, Y8 distributor and 4 wire 02 sensor. And switch to obd-1. I will never make that mistake again. I am converting to obd-1 in the summer, I can't wait.
Old Mar 14, 2005 | 05:54 PM
mr. carpenter's Avatar
Default Re: mini me ecu Q (Mach69)
you use the ecu to match the head. i think it's a p28? to use the pm6 you'll have to get it modded at zdyne or hondata.
Godspeedmj
Apr 22, 2010 03:17 PM
bobbymoon
Jun 11, 2009 04:34 PM
trustnoone7935
Nov 24, 2004 08:34 PM
mellon
Sep 13, 2004 06:36 PM
ridestrt
Jan 20, 2004 12:18 PM
