HELP - Can't adjust valves
Old Mar 14, 2005 | 10:40 AM
quicksol95's Avatar
Default HELP - Can't adjust valves
what would make it so you can't adust the valves?
the head is a b18b head with 402t cams, supertech springs and retainers, and stainless steel valves.
we can adjust all but 6 valves on the head?
anyone have this issue before
or if you have any idea help us out
thanks in advance
Old Mar 14, 2005 | 02:01 PM
NJIN BUILDR's Avatar
Default Re: HELP - Can't adjust valves (slow90hatch)
The valve stem length is to long.The helms manual will give you the proper height.The tips will probably need to be ground shorter.I assume you can't back the adjuster off far enough(not enough clearance).
Glenn
Old Mar 14, 2005 | 05:47 PM
quicksol95's Avatar
Default Re: HELP - Can't adjust valves (NJIN BUILDR)
after taking the head back off it seems the valve seats are shot
Darrell Woods
Feb 1, 2021 05:20 AM
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
SirRevvs
Oct 14, 2010 10:32 AM
Xscort
May 21, 2009 08:09 PM
S13 slide
Mar 24, 2006 02:25 PM
