thirsty GSR?
Old Mar 14, 2005 | 09:11 AM
00ekhatch's Avatar
Default thirsty GSR?
would the stock fuel pump in a 2000 civic dx supply enouph of the go-juice to a 97 gsr with skunk2 intake manifold? if not what are some good ways to make sure i am not starving the motor?thanks in advance...
Old Mar 14, 2005 | 06:51 PM
Hapexamendios EJ8's Avatar
Default Re: thirsty GSR? (00ekhatch)
99% sure that it will not
Old Mar 15, 2005 | 12:02 AM
Humble1's Avatar
Default Re: thirsty GSR? (Hapexamendios EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapexamendios EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">99% sure that it will not</TD></TR></TABLE>
stop giving wrong info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ekhatch &raquo;</TD></TR><TR><TD CLASS="quote">would the stock fuel pump in a 2000 civic dx supply enouph of the go-juice to a 97 gsr with skunk2 intake manifold? if not what are some good ways to make sure i am not starving the motor?thanks in advance...</TD></TR></TABLE>
i myself have a 94 civic ex with stock fuel pump and a 94 gs-r swap. everything runs fine with no fuel problem whatsoever..you will be fine with the stock pump.
Old Mar 15, 2005 | 01:29 PM
00ekhatch's Avatar
Default Re: thirsty GSR? (Humble1)
well, your 94 EX was a vtec motor prior to the swap, mine was not. in fact the 2000 dx is such an econo-box i am starting to wonder if the fuel pressure is lacking in certain areas. what should the fuel pressure be so that i can make sure that i am not starving my gsr.
Old Mar 16, 2005 | 04:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humble1 &raquo;</TD></TR><TR><TD CLASS="quote">stop giving wrong info
i myself have a 94 civic ex with stock fuel pump and a 94 gs-r swap. everything runs fine with no fuel problem whatsoever..you will be fine with the stock pump.</TD></TR></TABLE> your the one giving wrong info bud
Old Mar 16, 2005 | 01:35 PM
00ekhatch's Avatar
maybe somone with the actual FACTS could respond. this is a TECH-website
not an OPINION forum. maybe somone could let me know the correct pressure that the GSR is supposed to have so that i can PROVE that my fuel pressure is not a problem. thank you.
Old Mar 16, 2005 | 01:42 PM
dustin's Avatar
http://hondata.com/techfuelpump.html
Old Mar 16, 2005 | 02:45 PM
SkRiBLaH's Avatar
Default Re: thirsty GSR? (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondata &raquo;</TD></TR><TR><TD CLASS="quote">This means that the fuel pump can flow enough fuel for large amounts of power if the the fuel pressure is kept low. This means that large injectors will need to be used.
What is important to note is that this pump (and most others) has an internal bypass valve that opens at 75 psi.
So from this graph, Hondas running the stock pump, and a rising rate regulator top out at 75 psi and about 200hp. So, this is not a good solution.
But, if you run your stock fuel pressure (say 40 psi) and this stock fuel pump, 650cc injectors will easily provide you fuelling for low 300 wheel HP. Honda computers will easily idle a 1600cc engine on 720cc injectors.</TD></TR></TABLE>
^Sammy]!.
Jul 12, 2005 08:33 AM
00ekhatch
Mar 16, 2005 06:27 AM
Todapwr
12
Oct 14, 2003 08:17 PM
Ricey McRicerton
Sep 27, 2003 08:24 PM
Witty
Jun 30, 2003 10:33 AM
