Getting my garaged sol back into driving mode...
Old Mar 14, 2005 | 07:31 AM
94sol_vtec's Avatar
Default Getting my garaged sol back into driving mode...
What precautions and/or actions should I take to get my 94 sol 1.6L vtec back on the road after keeping it in the garage all winter - - i only started it a few times - - only drove it twice - - and never actually winterized it - - (stupid, i know) - - what do i need to do now to get it back to normal driving condition - - i know i cant just start driving it...
thanx for the help...
Old Mar 14, 2005 | 07:48 AM
saxqtzk's Avatar
Default Re: Getting my garaged sol back into driving mode... (94sol_vtec)
1. change the motor oil and oil filter
2. Check tire pressure
3. Make sure all fluids are topped off
and I think that's it.
Old Mar 14, 2005 | 07:55 AM
bbarbulo's Avatar
that, plus drain your gasoline and fill with fresh stuff. gas goes stale
Old Mar 14, 2005 | 07:56 AM
bbarbulo's Avatar
ooops I forgot... also add Seafoam or some other strong cleaner to your gasoline cuz your injectors are prolly clogged from gasoline varnish deposits.
Old Mar 14, 2005 | 08:45 AM
94sol_vtec's Avatar
Default Re: (bbarbulo)
whats the best way to go about draining the old gasoline - - sounds like a mess
thanks so far...
Old Mar 14, 2005 | 09:09 AM
bbarbulo's Avatar
some tanks have a bolt at the bottom to drain it... in other cases, you have to syphon it out... get a transfer 'pump' from Walmart... a lil hand pump you can syphon gas with.
Filthy Focker!'s Avatar
Default Re: (94sol_vtec)
If the car starts fine, you don't need to drain the fuel from the tank. Just do what saxqtzk wrote:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxqtzk &raquo;</TD></TR><TR><TD CLASS="quote">1. change the motor oil and oil filter
and you should be fine. I store my motorcycle from october to april/may every year and never had a problem.
fs
Old Mar 14, 2005 | 09:16 AM
94sol_vtec's Avatar
Default Re: (filthy_shovel)
would adding b12 chemtool cleaner to the oil and running it awhile with the old oil and then changing it be a bad idea?? the instructions say to run it awhile in the oil and then change the oil immediately...
Old Mar 14, 2005 | 09:19 AM
Just drain the oil and that's it. No chemicals or anything else.
Listen, drain engine oil, charge battery and crank it over. Let it run for about 10 minutes. If it hiccups or something, maintain idle with throttle. Then take it out for a spin. It should be fine. It is the same thing as buying a new car that has been sitting on the lot for 3 months. Nothing is damaged or clogged on your car.
fs
Old Mar 14, 2005 | 09:26 AM
94sol_vtec's Avatar
great! - - i cant wait to get back on the road
thanks alot
Old Mar 14, 2005 | 09:55 AM
beaterdriver's Avatar
my car sat for 4 months, changed the oil made sure the tires were full, and off i went, still runnin strong
Old Mar 14, 2005 | 01:05 PM
Falqon's Avatar
Default Re: (beaterdriver)
I heard that it was a good idea to turn it over a couple times before letting it start? Maybe someone smarter can say that's an awful idea.
Old Mar 14, 2005 | 07:45 PM
94sol_vtec's Avatar
Default Re: (Falqon)
okay, heres what i did:
1. checked tire pressure
2. checked fluid levels - - and filled the low coolant
3. changed the oil and filter
4. put 4 cylinder engine restore and lubricant in the motor
5. kissed it for luck...
its now running better than it has ever since ive had it - - as far as i can remember
its great to be driving again...
thanks guys...
Old Mar 14, 2005 | 08:24 PM
saxqtzk's Avatar
If you're concerned about the gas I would get some fresh gas and pour it in your tank... But I agree that gas that sits in the tank for long periods of time don't do any good.
Old Mar 15, 2005 | 06:57 AM
94sol_vtec's Avatar
Default Re: (saxqtzk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxqtzk &raquo;</TD></TR><TR><TD CLASS="quote">If you're concerned about the gas I would get some fresh gas and pour it in your tank... But I agree that gas that sits in the tank for long periods of time don't do any good.
oh yeah... it started right away without a problem and as soon as i did all of the above i filled it up with fresh gas...
Old Mar 15, 2005 | 07:34 AM
senpai's Avatar
next time, use STABIL fuel stabilizer (when storing)
Old Mar 15, 2005 | 11:02 AM
94sol_vtec's Avatar
Default Re: (senpai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai &raquo;</TD></TR><TR><TD CLASS="quote">next time, use STABIL fuel stabilizer (when storing)</TD></TR></TABLE>
keeps your gas from going stale... i assume??
Old Mar 15, 2005 | 01:00 PM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94sol_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
keeps your gas from going stale... i assume??</TD></TR></TABLE>
si
grape1161
Aug 20, 2010 01:23 PM
Droid407
Jun 23, 2009 05:28 PM
305S0L
Dec 31, 2007 01:54 PM
kidwit93delsol
Dec 2, 2007 07:30 PM
Chewy[Ek]
Oct 24, 2006 10:20 PM
