ROD KNOCK in my poor mans R..what to do?
Old Mar 14, 2005 | 06:07 AM
B18cHatch06's Avatar
Default ROD KNOCK in my poor mans R..what to do?
ok well im runnin a poor mans r setup and as of last week..it has rod knock like a ****...i took it to my cousin who said ill need to replace my crank, rods, bearings..soo im figuring should i go ahead and build it up with a 11:5.1 piston/eagle rods and use a stock crank? or what crank would yall prefer to build a better setup? perhaps stroker? let me know..
i was gonna buy a 04 gsr-r600..but not that i have to fix my motor..im probly gonna build it to make like 200+whp..let me know whats best for my bottom end..top is alrewady being build with blox s2 cams springs,retainers..ran on hondata s100
or let me know
Old Mar 14, 2005 | 07:38 AM
lemongreenhatch's Avatar
Default Re: ROD KNOCK in my poor mans R..what to do? (B18cHatch06)
go with ls crank... up the compresion a lil more... so u spun a bearing?...change ur oil pump
Old Mar 14, 2005 | 07:56 AM
Default Re: ROD KNOCK in my poor mans R..what to do? (poorman's-allmotor)
yea i was thinking about getting an ls crank/eagle rods/either je,cp,arias 11:5.1 compression pistons
so i need a new oil pump? or its just better off i get 1 to be safe?
is the setup i wanna run worthy of 200+ mayb 210+whp or even higher with a nice header?
Old Mar 14, 2005 | 08:05 AM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cHatch06 &raquo;</TD></TR><TR><TD CLASS="quote">yea i was thinking about getting an ls crank/eagle rods/either je,cp,arias 11:5.1 compression pistons
is the setup i wanna run worthy of 200+ mayb 210+whp or even higher with a nice header?</TD></TR></TABLE>
You might not want to run the S2 valve springs, a lot of horror stories out there. If you do decide to use the LS crank, make sure that you blueprint & balance the rotating assembly. Search, theres a lot of helpful info here.
Old Mar 14, 2005 | 08:39 AM
totsie7944's Avatar
you won't hit 200 wheel with that IMO. you will need a litle more work.
Old Mar 14, 2005 | 08:49 AM
Default Re: ROD KNOCK in my poor mans R..what to do? (totsie7944)
the setup when done will be
b18c1 block
balanced ls crank
eagle rods
arias or je 11:5.1(around there) compression pistons
as for the head..its a jdm b16 head
blox s2 cams will be put in with springs/retainers (havnt decided which 1's yet)
as of right now..i have a jdm dc 4-1 header with 2.5 all the way back with an n1 muffler..if its worth it im going to get a smsp header..
aem CAI with skunk 2 IM
and is gonna be tuned with hondata s100
200whp? i think ill make it especially with the custom header..
any other suggestions let me know..ill keep in on how the setup is going
Old Mar 14, 2005 | 08:52 AM
totsie7944's Avatar
with the smsp header you probably will hit 200 wheel. but you might needa little higher compression for more power after that.
Old Mar 14, 2005 | 09:04 AM
yea 200 is all i really want..this is gonna be my daily driver...n a lil weekend fun
not gonna go any higher on the compression...93 octane is the highest i know of around here in S florida without driving an hour...soo ill keep it around 11:5.1
kyosoeg6
11
May 16, 2011 06:39 PM
eg6madness
11
Apr 19, 2010 08:14 PM
civic-8442-
Jun 14, 2008 01:27 PM
love2xlr8integra
May 2, 2004 08:00 PM
SCsol
Mar 10, 2002 11:51 AM
