Half Core Radiator with Peakboost turbo kit?
Im getting ready in the next few months to cross over to the dark side. I got my motor built but im having a few setbacks.
The peakboost kit calls for a half core civic si radiator.
How has people mounted it?
I was looking on ebay for radiators and such I came across this-
Its a half core radiator, but the bottom goes out further so it will "drop" right in the stock location so theres no modification.
Anyone used this?
What did everyone else wind up doing?
Anyone used this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpm11 »</TD></TR><TR><TD CLASS="quote">I drilled out the spotwelds on the radiator mounts and used them for the 1/2 width
Fluidyne.</TD></TR></TABLE>
+1
+1
I have been watching this Gorilla Arm radiator as well... I have called them in reference to this RAD and they said it has the same cooling as the C&R and they will weld whatever fan bolts you need so if you want to rock a stock fan you can or a slim you can do as well.... I havent made a desicion yet cause they run $350 w/out fan you can get a KOYO for $280 so not sure if it is worth the $70 just to retain the stock mount positions....
