Suspension & Brakes Theory, alignment, spring rates....
eibach pro kit w/ stock shocks
Old Mar 14, 2005 | 01:21 AM
Wazup's Avatar
Default eibach pro kit w/ stock shocks
anyone running an eibach pro kit with stock shocks? just wondering if they are comfortable or produce any problems.
Old Mar 14, 2005 | 03:55 AM
accordmaniac's Avatar
It should be okey.. but going with Koni Yellow will make you happy camper!
Old Mar 14, 2005 | 10:53 AM
att1203's Avatar
Default Re: eibach pro kit w/ stock shocks (Wazup)
You'll be fine. Majority of the Pro-kits were made to go with stock shocks. You'll still maintain a stock ride. Had them on my 02' TL and I loved it. But like AccordManiac said, it'll be much better with aftermarket shocks.
Old Mar 14, 2005 | 01:39 PM
Wazup's Avatar
Default Re: eibach pro kit w/ stock shocks (att1203)
would i have to worry about camber problems? pro kits usually only drop less than half an inch
Old Mar 14, 2005 | 01:59 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wazup &raquo;</TD></TR><TR><TD CLASS="quote">would i have to worry about camber problems? pro kits usually only drop less than half an inch</TD></TR></TABLE>
don't worry about camber. Get an alignment afterwards to sort out any toe change and call it a day. They "should" be fine with stock shocks, although I blew a stock shock a little while after installing my pro-kits. It may have been a bad shock, and it had around 70k miles on it.... your results may vary .
Old Mar 16, 2005 | 09:47 AM
fsp31's Avatar
Default Re: eibach pro kit w/ stock shocks (nonsense)
About a hundred years ago...
The rear struts on my EK hatch lasted 8 months with Pro-kits (i'm guessing it was speed bumps that killed them). So I ebay'd the springs and bought GC's like I should have done in the first place.
Old Mar 16, 2005 | 10:50 AM
Db1_77's Avatar
well, considering Eibach only drops your car a little over an inch i don't see where you'll run into any camber issues.
Just remember, the lower you take your car the shorter your struts life will be.
choughster
Suspension & Brakes
Dec 9, 2007 04:38 PM
02rsx-s
Apr 30, 2006 04:38 PM
stevn
Oct 16, 2005 08:14 PM
pburke23
Jul 12, 2004 11:43 AM
lowlight
Jul 11, 2003 01:13 PM
