honda test spot: oil pressure.
Old Mar 14, 2005 | 12:32 AM
JDMorgan's Avatar
Default honda test spot: oil pressure.
when honda needs to test your car for oil pressure where would they put the gauge for an integra? i heard they use the plug on the front passanger side of the head right in front of the cam plug. is this true? would it be possible to use this to supply oil for a turbo?
Old Mar 14, 2005 | 04:24 AM
havok hybrid's Avatar
Default Re: honda test spot: oil pressure. (KraZEtEggIE)
Honda motors have a sensor factory on the motor that looks for oil pressure.. .. Its the light on the dash!!..
Its on the back of the motor .. next to the oil filter .. with only ONE wire on it...
this is where you want to tap for turbo ... OR test for oil pressure.. Or both ..
did that help out ?
Old Mar 14, 2005 | 05:27 AM
mmuller's Avatar
Mad Scientist
you mean the vtec oil pressure test port? no it will not work since it only reads pressure when vtec is engaged
Old Mar 16, 2005 | 08:17 AM
civic-4-ges's Avatar
Default Re: honda test spot: oil pressure. (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you mean the vtec oil pressure test port? no it will not work since it only reads pressure when vtec is engaged</TD></TR></TABLE>
No...the oil pressure sensor that is on the back of the block, right near the oil filter!
Old Mar 16, 2005 | 08:34 AM
drdisco69's Avatar
Default Re: honda test spot: oil pressure. (civic-4-ges)
Yeah, just use the oil pressure sensor fitting on the back of the block.
Old Mar 16, 2005 | 08:37 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">No...the oil pressure sensor that is on the back of the block, right near the oil filter!</TD></TR></TABLE>
ok....thats what i was sying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">i heard they use the plug on the front passanger side of the head right in front of the cam plug. is this true? would it be possible to use this to supply oil for a turbo?</TD></TR></TABLE>
Old Mar 16, 2005 | 08:48 AM
My bad!!! I assumed YOU knew better!!!
Old Mar 16, 2005 | 09:01 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">My bad!!! I assumed YOU knew better!!! </TD></TR></TABLE>
god dude, get off my nuts....
havok hybrid already sayd where the stock pressure sensor loc. was at.
i was just clearing up what the port on the head was for..
Old Mar 16, 2005 | 02:54 PM
i was just clearing up what the port on the head was for..</TD></TR></TABLE>
Oh man...I was not giving you **** at all, take that last statement as joking around please!
Old Mar 16, 2005 | 07:58 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Oh man...I was not giving you **** at all, take that last statement as joking around please!</TD></TR></TABLE>
oh dude, i apologize; i got your idea the wrong way; you know how people are around here... my bad
tobster
Mar 13, 2011 12:32 PM
bosco500
Apr 5, 2005 03:57 PM
