Cam timing help needed
Old Mar 14, 2005 | 12:03 AM
Redsun's Avatar
Default Cam timing help needed
I'm using a thicker 1.5mm headgasket due to high compression pistons in my B20 and ITR head and Skunk stg 2 setup. Will my cam timing need to tuned because of this?
I just want to set the Cam gears at zero until i get the valve to piston clearances done and until i can tune it properly on dyno but due to the thick gasket if i leave them on zero, then they won't really be on zero?? They will be slightly advanced but i'm not too sure how much so i need to know how much to retard them by in order to acheive zero.
Sorry for the long post and hope it all makes sense.
Old Mar 17, 2005 | 08:19 AM
Redsun's Avatar
Default Re: Cam timing help needed (Redsun)
Old Mar 17, 2005 | 01:13 PM
Padawan's Avatar
Darth ModerVader
The generally-accepted approximate formula is that, for every 0.3 mm you add to the deck height, you will want to retard cam timing by 1° to arrive at at "0,0" setting.
Old Mar 18, 2005 | 07:28 AM
Redsun's Avatar
Default Re: Cam timing help needed (Padawan)
Thanks dude.
EGDriver93
17
Feb 24, 2011 10:16 AM
hondafan62269
Jan 7, 2005 09:34 PM
itr1236
Dec 9, 2001 05:09 PM
