Need help B16 HF swap
Old Mar 13, 2005 | 09:57 PM
91B16HF's Avatar
Default Need help B16 HF swap
I tried searching and came up with nothing. What is needed for the B16 swap into an HF. The car already has a DOHC zc swap with a locked up cam. Any help is appreciated.
Old Mar 13, 2005 | 10:00 PM
Magick211's Avatar
Default Re: Need help B16 HF swap (91B16HF)
You did not use a good search method then
Well anyway you will need
motor
tranny
ecu
si/dx knuckle hub assemably
90-93 teg axles and intermediate shaft
mount kit
and custom shift linkage if your swap dont come with sir linkage
Old Mar 13, 2005 | 10:01 PM
Redline130's Avatar
Before you get flamed harshly, have you tried search both recent topics and the archives. There are tons of posts about swapping a B16 into an EF.
b16 into crx returned 29 results in recent topics.
Old Mar 13, 2005 | 10:14 PM
91B16HF's Avatar
Default Re: Need help B16 HF swap (Redline130)
Thanks alot so far I've got the mounts and linkage since it already has the swap I got the axles
Old Mar 13, 2005 | 10:17 PM
aaronhume's Avatar
you will need integra axles and halfshaft, because the ZC/D series use different axles. I have a halfshaft if you want... pm me if interested. I was able to get some rebuilt oem axles on ebay for $130 shipped
Old Mar 13, 2005 | 10:19 PM
aaronhume's Avatar
Default Re: Need help B16 HF swap (aaronhume)
also, be prepared to spend an extra $500 on misc. stuff like distributor, header, and anything else... very helpful btw you should get a new clutch with it and timing belt and water pump and crap (don't go to shucks they are retarded with matching parts, start at the engine importer)
Old Mar 14, 2005 | 01:37 AM
NikoZai's Avatar
COMPLETE LIST OF PARTS
http://www.droppedcrxsi.com
also, a wiring option - rywire.com
(dizzy adapter - ZC to B16.. not on website but we can make it)
Old Mar 14, 2005 | 06:52 AM
4gCRX's Avatar
Default Re: Need help B16 HF swap (NikoZai)
[QUOTE=NikoZai]COMPLETE LIST OF PARTS
Sweet
hondatuner020
12
Dec 27, 2007 06:32 AM
freak86
Oct 20, 2006 07:51 PM
wrXtian
Jul 26, 2003 11:11 PM
camera obscura
11
Mar 27, 2003 06:40 PM
