b16a1 rebuild/ build up
ok, im new here, so please help. i am rebuilding/ building up my b16a1 for my 89 civic si. i am porting and polishing the head, 3 angle valve job, port match everything, polish the crank, hone the block, maybe mill the head. i found out the other day that the guy doing this is going to have to bore the block for me cause of clearance issues. he is going .20 or .25 over. what pistons can i run? can i use a set of ctr pistons and what else would i need besides pistons and rings? do i need different rods, crank or anything? also this motor has gsr cams. guy i got it from put those in there. please help, thanx
nice hatch. All of this stuff u can find easily using the search function, just set it to the all motor forum and search for all those things. You'll find a lot of good info especially in this forum.
