leakin oil in spark plug
98 gsr. today as i was tryin to change my spark plug. when i pulled out the spark plug tube thing there was oil in there. the 3 spark plug on the left was fine and dry but the one in the far right had a good amount of oil in it. is something leakin? what should i do im worried about my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by balch104 »</TD></TR><TR><TD CLASS="quote">need new valve cover sealant things i forgot what they are called. its the rubber triming that u put on ur valve cover. </TD></TR></TABLE>
valve cover gasket?
valve cover gasket?
ya.. change the spark plug seals and valve cover seal.
my spark plug seal was leaking into my #2 cylinder and had oil like you say.. cheap and easy to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegr »</TD></TR><TR><TD CLASS="quote">how do i go about changin the spark plug and valve cover seal. do i need take out the hole valve cover?</TD></TR></TABLE>Yes you do, but it's pretty easy. But be careful, because it's also very easy to overtighten & break the studs (#18) that hold the valve cover down.
You need the sparkplug tube seals #7. Maybe get 'em together in a kit with the VC gasket #5 and the grommets #23.
yep happened to me and i ended up not knowing what to do and put on a whole new head gasket while i was at it..
okay i intsalled it today everything looks good. i had to stuff napkins in the spark plug hole to drain out all the oil though which was a bitch. hopemy copper plugs would be fine tho ohh yeaa u dont even need to use the valve cover seal! that was useless just stick with the spark plug seal and if ur at it change all 4.
couple of drops fell on the header when i was removing the valve cover. when i was turning on the engine the header had steam coming out of it, for a split second i thought my engine was burning up or something LOL
redpeppers
Jul 15, 2005 04:17 AM
