changing my brakes question???
Old Mar 13, 2005 | 08:44 PM
rolledthatho's Avatar
Default changing my brakes question???
hey guys once before i changed the brakes on a friends maxima and while i was compressing the piston the pressure blew fluid out where the brake likes seat under the resivoir, theres usually like 2 posts below the res.. well i blew one out... i teflon tapped it back in and it seated fine, but what can i do to prevent this, would it be a bad idea to jus take the lid off the resivior? or will that put air in the system
on my mustang i always just compressed the pistons and went on, but i dont want anything to happen to the car im working on so
what should i do, its a normal brake change
Old Mar 14, 2005 | 06:51 AM
JimBlake's Avatar
Default Re: changing my brakes question??? (rolledthatho)
Take off the brake fluid reservoir cap. Compress the pistons slowly & watch the fluid. You may have to suck some out so it doesn't overflow. The cap has a very small vent, you can't hardly push fluid out thru that.
Probably your mustang had a bigger vent? Or maybe the fluid wasn't so high & it never overfilled?
If your pressure lines leaked, teflon tape isn't the way to fix it...
Old Mar 14, 2005 | 10:05 AM
"If your pressure lines leaked, teflon tape isn't the way to fix it..."
yeah i know it wasnt the way to fix it, but it worked never leaked again and drove it for another 3 yrs
thanks for the info tho!
creator1322
12
Jun 6, 2010 04:08 AM
bopbop93030
May 9, 2008 07:01 PM
full Circling
Jul 12, 2004 06:12 AM
Driven
Jul 23, 2003 06:21 AM
Floyd
Oct 28, 2001 03:40 PM
