[HELP] can i install EK suspension to EG and EG suspension to EK?
Old Mar 13, 2005 | 07:20 PM
i20444406's Avatar
Default [HELP] can i install EK suspension to EG and EG suspension to EK?
please help
Old Mar 13, 2005 | 07:23 PM
gabspeed's Avatar
Default Re: [HELP] can i install EK suspension to EG and EG suspension to EK? (i20444406)
not on the back unless you swap the rear lower control arms around with it besides that yes it will bolt right on
Old Mar 13, 2005 | 07:49 PM
Mr.Hatch's Avatar
Default Re: [HELP] can i install EK suspension to EG and EG suspension to EK? (gabspeed)
I have 93 Si rear discs on my 99.
So the answer is yes you can.
Old Mar 13, 2005 | 08:45 PM
ABK's Avatar
ABK
Default Re: [HELP] can i install EK suspension to EG and EG suspension to EK? (Mr.Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I have 93 Si rear discs on my 99.
So the answer is yes you can.</TD></TR></TABLE>
That doesn't mean anything.
You can swap EG suspesion on EK (except you will need to shim out the rear shock between shock and LCA). But you can't do EK to EG because you will have nowhere to mount brake lines upfront, and you won't be able to fit the rear shock over the LCA.
Old Mar 13, 2005 | 09:48 PM
ironcheftony's Avatar
you can do eg to ek easily
for ek to eg, you need to be creative
- front bolts in, zip tie brake lines on
- rear bolts in, just need to cut down the middle lca bushing about 1/4" on both sides maybe more, i forgot
i did this last week, no problems
1 jonesie
May 20, 2007 05:08 PM
KillBot
Mar 12, 2005 10:56 AM
RHDintegXsi
Suspension & Brakes
Mar 11, 2005 08:38 PM
ATS*Mark
15
Mar 16, 2003 12:31 PM
evil_elmo
Jan 16, 2002 11:36 PM
