CAMS for h22 turbo?
Old Mar 13, 2005 | 04:41 PM
bjfisher's Avatar
Default CAMS for h22 turbo?
which cams should i look into for my setup?its a built h23 block with a h22 and turbonetics 60-1 p-trim .81ar .more of a track car but still drive on the street every now and then.if you need to know more of my setup lemme know.....
Old Mar 13, 2005 | 07:40 PM
Dragline's Avatar
Default Re: CAMS for h22 turbo? (bjfisher)
Type S cams
Old Mar 14, 2005 | 05:57 AM
bjfisher's Avatar
for turbo....????
Old Mar 14, 2005 | 06:08 AM
Dragline's Avatar
Default Re: (bjfisher)
Ya what did you have in mind or should I say what cams are you looking at.
Old Mar 14, 2005 | 06:29 AM
Daemione's Avatar
Default Re: (dragline)
Crower makes turbo specific H22 cams, they're the only ones I know of available off-the-shelf. Anything else would have to be custom ground.
Type S cams might work with adjustable cam gears & the right tuning. But if it were me I'd just stick with stock if you can't afford the Crowers.
Old Mar 14, 2005 | 09:02 AM
bjfisher's Avatar
i have no idea what i was looking at, but i didnt think stock cams would be the choice
money isnt the thing, im building the rest of the motor so cams might as well be part of it, but i was jus looking for a good set for a turbo application
Old Mar 14, 2005 | 11:31 AM
Dragline's Avatar
Crower cams suck they are just a pour casting I personally know 4 people that have broke them,you would be surprised how many people run the TYPE S cams on turbo cars,if money's not a problem check out Crane there roller cam setup is awesome.
search on here about crower cams.
Old Mar 14, 2005 | 11:37 AM
bjfisher's Avatar
ok thanks
anyone with type s cams?and turbo
Old Mar 14, 2005 | 04:15 PM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Crower cams suck they are just a pour casting I personally know 4 people that have broke them,you would be surprised how many people run the TYPE S cams on turbo cars,if money's not a problem check out Crane there roller cam setup is awesome.
search on here about crower cams.</TD></TR></TABLE>
Old Mar 14, 2005 | 05:19 PM
bjfisher's Avatar
^^ what cams you runnin?your boosted right?
Old Mar 29, 2005 | 04:54 PM
h22 civic's Avatar
theri really aint much out theri and quite frankly unless syour makeing monster power know and want to up grade cams for that reason i would look into a set of crane but for your mild h22 build up 550 whp type s cams work good .......if your looking to make more go crane if you are not makeing 4-5 hundred stick with your stockers and spend the money elswhere on the motor or drivetrain
Old Mar 29, 2005 | 09:34 PM
Moemers's Avatar
ok im so curious now....why type s cams? we're talking RSX-S right? why those cams?
Old Mar 30, 2005 | 03:32 AM
bjfisher's Avatar
prelude type s, not rsx-s
Old Mar 30, 2005 | 09:30 AM
jamey220's Avatar
id do the type s cams
Old Mar 30, 2005 | 10:57 AM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjfisher &raquo;</TD></TR><TR><TD CLASS="quote">prelude type s, not rsx-s</TD></TR></TABLE>
95whiteeg6
Jul 14, 2010 08:11 PM
jdm knight
Oct 13, 2008 07:00 AM
purpleh22
Jan 18, 2006 11:00 AM
Drum_Guru
Jan 20, 2004 05:41 PM
eg:R
Jul 22, 2003 01:31 PM
