ls cable trans with b16 shift linkage
im wondering if this combo would work.. and what axles would i need to use for the ls trans to work in a 91 crx hf.. thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 »</TD></TR><TR><TD CLASS="quote">im wondering if this combo would work.. and what axles would i need to use for the ls trans to work in a 91 crx hf</TD></TR></TABLE>
The LS cable tranny will work fine with a B series motor, but the B16 linkage will not work unless you cut it, reweld and make it work. As for the axles, it's best to use a 90-93 Integra intermediate shaft and axles.
There isn't a direct fit linkage for a B series EF swap. You can use a DA Integra linkage or JDM EF B series linkage but either way they will have to be cut and rewelded to fit. You should buy a linkage from the manufacturer of the mount kit you use.
bubba3369
Aug 30, 2009 07:14 PM
crunkedhatchbacks
Feb 9, 2006 04:27 PM
