secondary butterflys help wiring
Old Mar 13, 2005 | 03:12 PM
jdm4dr's Avatar
Default secondary butterflys help wiring
in the helms manual it shows the evap..im not quite sure. i need to know what the secondary butterfly sensor is actually called and its 2 wired that need to be wired. i need a little help
thanks
Old Mar 13, 2005 | 03:14 PM
white99gsr's Avatar
Default Re: secondary butterflys help wiring (jdm4dr)
its a two wire plug under manifold attached to a black vacuum box. one wire is black (thermostat ground) and the other is pink/blue (ECU).
Old Mar 13, 2005 | 09:07 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm4dr &raquo;</TD></TR><TR><TD CLASS="quote">in the helms manual it shows the evap..im not quite sure. i need to know what the secondary butterfly sensor is actually called and its 2 wired that need to be wired. i need a little help
thanks</TD></TR></TABLE>
IAB = Intake Air Bypass control solenoid valve (C134 on Helms diagram)
Pink/Blue wire connects to A26 on OBD2 P72. The other wire is grounded.
dperry
Mar 24, 2014 06:46 AM
tdo
Feb 28, 2008 01:37 PM
PhrequenC
Audio / Security / Video
41
Jul 5, 2007 04:08 PM
Batoutahell
Jan 29, 2006 06:45 AM
CTRwannaB
Dec 6, 2003 04:52 PM
