Lighting HID/Xenon kits, Retrofits and Associated Topics
HIDs in a DA?
Old Mar 13, 2005 | 03:00 PM
JunTec's Avatar
Default HIDs in a DA?
Does anyone know if its possible to put HIDs in a DA?
I have a 91 integra and i have the JDM one peice headlights.
Ive heard around that it can melt the houseing of the headlights.
But i want to know if anyone has ever done it before.
Thanks in ADVANce...
Old Mar 13, 2005 | 03:31 PM
jizno's Avatar
Default Re: HIDs in a DA? (JunTec)
burning the fixture is a drawback of HIDs, it COULD happen in any car with and light fixture, unless the fixture states otherwise by manufacturer.
Old Mar 13, 2005 | 03:37 PM
NightRiderS2K's Avatar
In-N-Out Burger
It's possible, but please don't put HIDs in your headlights. The light will scatter everywhere and you will end up blinding oncoming traffic.
And just for ***** and giggles, HID bulbs operate at 35watts compared to their halogen counterparts which operate at 55watts. It will not melt the housing of any headlights period.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jizno &raquo;</TD></TR><TR><TD CLASS="quote">burning the fixture is a drawback of HIDs, it COULD happen in any car with and light fixture, unless the fixture states otherwise by manufacturer.</TD></TR></TABLE>
Old Mar 13, 2005 | 04:25 PM
ali_232's Avatar
go to http://www.g2ic.com
and under teg tips
Old Mar 13, 2005 | 07:10 PM
JunTec's Avatar
Default Re: (ali_232)
Thanks guys...
And yea im a member at g2ic
Old Mar 13, 2005 | 07:16 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have seen someone retrofit an OEM HID projector into JDM housings, and polish the flutes out of the plastic lens in front of the projector. That's the only proper way to get HID on a DA. Any other method will suck, I can guarantee that 100%.
Old Mar 14, 2005 | 12:39 AM
FR-MOB: ThE bEe GuY's Avatar
Default Re: HIDs in a DA? (PatrickGSR94)
I heard its ok to get HIDs without a projector if you get the D2R bulbs. Theyre made with a glare guard strip on the bulb to help it reflect the correct way in reflector housings. D2S is for projectors. Also, HIDs wont blind on coming traffic if you just adjust your headlights correctly, and get the right bulbs for the right housings.
It's still a lot better to retro projectors into your lights though, the cutoff will be a LOT better
Old Mar 14, 2005 | 04:32 PM
Community Builder
Default Re: HIDs in a DA? (ThE bEe GuY)
From what I've seen, D2R bulbs in halogen reflector housings are still pretty poor. Yeah you can keep them from having alot of glare if you use the correct shielding, but you still don't get the light performance you need on the ground in front of the car.
Hell, I don't even like OEM HID reflector headlights. The previous gen Maximas w/ reflector HID was one of the worst OEM HID setups on the road, according to the rating chart that I've seen on the lighting FAQ site.
Old Mar 14, 2005 | 06:48 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Hell, I don't even like OEM HID reflector headlights. The previous gen Maximas w/ reflector HID was one of the worst OEM HID setups on the road, according to the rating chart that I've seen on the lighting FAQ site.</TD></TR></TABLE>
I have no direct experience with the Maxima reflector HID setup, but the system in my QX4 is quite good. The cutoff is not as razor sharp as a projector setup, but it is still very well controlled, and the beam pattern and dispersion is nice and even. Just as there are some projector setups that perform better than others, I think you'll find that so too are there varying levels of performance with reflector-based systems.
Old Mar 18, 2005 | 12:57 PM
DA-nteg's Avatar
Default Re: HIDs in a DA? (Padawan)
https://honda-tech.com/zerothread?id=1180038
Old Jan 26, 2008 | 06:31 PM
posHonda's Avatar
Default Re: HIDs in a DA? (integraswtrde)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraswtrde &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
3 years late this time
Old Jan 26, 2008 | 07:43 PM
DA_9's Avatar
Default Re: HIDs in a DA? (posHonda)
Yea it's possible
My Teggy
Old Jan 26, 2008 | 08:06 PM
denraweb's Avatar
Default Re: HIDs in a DA? (DA_9)
H4H JDM DA Headlight HID Kit
Old Jan 26, 2008 | 08:52 PM
Rikter's Avatar
Putting HID lights into any vehicle is possible... duhhhhhhhhhhhhhhhhhhhhhhh.
Nice scatter beam DA_9. Must get a lot of people in oncomming traffic flash their high beams at you.
-Rik
Old Jan 26, 2008 | 09:56 PM
JunTec's Avatar
Default Re: (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">Putting HID lights into any vehicle is possible... duhhhhhhhhhhhhhhhhhhhhhhh.
-Rik</TD></TR></TABLE>this thread is 3 years old duhhhhhhhhhhhhhhh!
Old Feb 3, 2008 | 06:56 PM
rsdriver17's Avatar
ebay special 150 or something with tsx hids
yes they are dry wall screws, i was in a hurry and never got around to finishing them
Old Feb 4, 2008 | 03:57 PM
integraswtrde's Avatar
Default Re: HIDs in a DA? (rsdriver17)
nice ! this thread although it's old it still helps out those DA peep's.
Old Feb 4, 2008 | 07:06 PM
bennyDA's Avatar
I have HID's in my 90 DA.. no retrofit yet... just plug n play kit fit right in
I have NEVER been flashed once NEVER been pulled over for HID's... I was flashed all the time with ultrastars or w.e their called... HID's plug n play/retrofit will work AMAZING... I have incredible light output... Dont listen to these people ill post pics when I find my camera
Old Feb 5, 2008 | 06:54 AM
Default Re: HIDs in a DA? (bennyDA)
is there any aftermarket da headlights that are already retrofited?
Old Feb 5, 2008 | 12:41 PM
bennyDA's Avatar
if you mean have projectors and you buy a PnP kit then yes... ebay has tons of jdm 1piece lights with "projectors" already...
Old Feb 5, 2008 | 01:24 PM
accordselux's Avatar
Me Gusta History
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennyDA &raquo;</TD></TR><TR><TD CLASS="quote">I have HID's in my 90 DA.. no retrofit yet... just plug n play kit fit right in
I have NEVER been flashed once NEVER been pulled over for HID's... I was flashed all the time with ultrastars or w.e their called... HID's plug n play/retrofit will work AMAZING... I have incredible light output... Dont listen to these people ill post pics when I find my camera</TD></TR></TABLE>
Post a pic of your output on a wall from at least 25 feet away.
kaotikvizion
13
Oct 25, 2009 10:42 AM
jdmbwoy
Mar 30, 2007 12:47 PM
AnthraxVX
Jun 12, 2006 12:12 PM
Showtime_III
Feb 19, 2005 03:54 PM
owens_18_2003
Jan 20, 2004 12:08 PM
