searched...Gsr engine
Old Mar 13, 2005 | 01:43 PM
94DOHCGsr's Avatar
Default searched...Gsr engine
my gsr engine has 121,xxx miles on it and ticks really loud when i start it up. When i start it, it idles at about 1500 rpm because it is cold but once it goes down to about 900 rpm, there is no noise. If i give it gas when it's at normal idle, it ticks again till it goes back down to normal idle.
I have already done valve adjustment and took off the heatshields and started the car and the motor still ticked. I am lost. Sounds like it is coming from the back side of the motor. I cant figure it out. Do you think that slick 50 might cure the tick if it is coming from the inside of the motor. Please help me because I am afraid of ruining my motor when i get on it a little.
P.S- its been doin it for about a year now.
Old Mar 13, 2005 | 01:45 PM
Kendall's Avatar
It could be injector noise.
Ls_V_TurboSi's Avatar
Default Re: searched...Gsr engine (94DOHCGsr)
My motor ticks when its cold too.. I dont think its that big of a deal
Old Mar 13, 2005 | 02:10 PM
94DOHCGsr's Avatar
Default Re: searched...Gsr engine (Ls_V_TurboSi)
i know the injectors are lound on gsr's but its not them..i hear a different noise.
Ls_V_TurboSi: It still happends when the motor has been running for a hour. If i rev it up to about 2-3k, it will tick for a second or two then go back to normal.
Anyone else? Please help because i want to figure this out before i go to the Great Lakes Dragaway.
Old Mar 13, 2005 | 02:14 PM
gsrboost's Avatar
LMA's might be doing the ticking. I know they are on my car. Ticks from 2000rpm - 3200rpm. Does the ticking get faster as the RPM gets faster?
Old Mar 13, 2005 | 03:51 PM
allmotorjdism's Avatar
Default Re: searched...Gsr engine (gsrsp33d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrsp33d &raquo;</TD></TR><TR><TD CLASS="quote">LMA's might be doing the ticking. I know they are on my car. Ticks from 2000rpm - 3200rpm. Does the ticking get faster as the RPM gets faster?</TD></TR></TABLE>
my buddys lost motions were bad in his b16 but you could tell when it was at an idle. Im sure if it was your lma's then you would hear it ticking at idle, but dont quote me on that.
Old Mar 13, 2005 | 04:01 PM
gsrboost's Avatar
Default Re: searched...Gsr engine (allmotorjdism)
Ya mine ticks alot on cold start ups. After it warms up it start ticking in the 2000-3000 range. I want to replace them but it is like $150 that i dont have right now.
Old Mar 13, 2005 | 04:59 PM
94DOHCGsr's Avatar
what are LMA's? Where are they located?
yah i think it does tick around that rpm...it doesnt get faster as the rpm get faster to what i have heard.
Thanks for all you respones..any more would be appreciated..
Old Mar 13, 2005 | 06:46 PM
gsrboost's Avatar
They are in the head. Do a search on LMA you will find a bunch of info. Sounds like that is your problem too.
Old Mar 13, 2005 | 07:42 PM
00s2KkId's Avatar
i changed my LMA's in my gsr...damn expensive little bastards..they ticked horribly at idle and up to around 4000 then quieted down cuz of the increasing rpm
Old Mar 14, 2005 | 01:26 PM
94DOHCGsr's Avatar
Default Re: (96GSRkId)
Do you guys think any engine treatment like slick 50 would solve the ticking? I would replace them if i had enough engine building experience but i am to afraid to mess up.
Old Mar 14, 2005 | 02:54 PM
rapid_roy's Avatar
Default Re: (94DOHCGsr)
2 things:
1. Check your oil and make sure you are not low. If it's full, proceed to step #2.
2. Go buy some Seafoam and read the can. Search for info for the inevitable questions you may have.
ok, 3 things.
3. Slick 50 is a waste of money and won't fix your problem which is probably a sticking lifter that step #2 will fix.
edit for clarification
DFW
Nov 18, 2004 01:57 PM
StupidSlowRSX
Jun 10, 2004 11:04 AM
vincent97gsr
Feb 15, 2002 08:20 AM
